Old 06-03-2003, 01:18 PM   #1621
Accord's Avatar
Send a message via AIM to Accord
Default Re: Something good on MYTSN
Originally posted by markp27
Just been browsing through some old articles on MYTSN and found the following three, which for a relative beginner, like me, seem pretty good:
http://www.mytsn.com/publ/publ.asp?pid=1985
http://www.mytsn.com/publ/publ.asp?pid=2157
http://www.mytsn.com/publ/publ.asp?pid=2178
Some nice simple explinations about car setup.
Cheers, Mark.
Wow, in that last link he actually suggests you use plastic shock bodies over aluminum shock bodies! He says the plastic ones are lighter and more consistent as they build up heat.
Accord is offline   Reply With Quote
Old 06-03-2003, 01:40 PM   #1622
markp27's Avatar
Send a message via ICQ to markp27
Never, to be honest. It's something I may try out, but I'd heard that it drains the battery or wears out the servo too quickly.
I would be interested to know how the ABS actually works, as normally (on a road car) sensors are required on the wheels to be able to sense when a wheel locks up.
Our RCs don't have any sensors and I can't see what kind of feedback can be given from the servo to the radio handset. I think that the ABS is probably a very crude system which may simply pulse the breaks.
It would be worth trying in the wet, just to see.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 06-03-2003, 01:45 PM   #1623
markp27's Avatar
Default Re: Re: Something good on MYTSN
Yep, I noticed that, too! Damn!!! Just bought some, too
Actually, from what I've read, they're supposed to be designed for when it's really hot.
Cheers, Mark.
Old 06-03-2003, 01:46 PM   #1624
Accord's Avatar
Cheers, Mark.
ABS does drain batteries quicker, however if you're using the proper servo you won't have any problems with excessive wear. If you're going to be using ABS, the best servo to use is a high speed digital servo. If you use a junky analog servo or a high torque servo, you'll fry the servo very quickly if you use ABS.
Our ABS is actually an ABS "simulator" as opposed to real ABS. All it does it pulse the servo very quickly, and with the 3PK you can fine tune it to pulse at a certain speed and you can also fine tune how much travel the actual pulse is. It actually works VERY well, my lap times are consistently 1 second quicker if I am using ABS because I can break a lot harder without fearing my car will spin out or go into a slide or something, it's too bad that it's not race legal .
Old 06-03-2003, 01:51 PM   #1625
markp27's Avatar
I was wondering if it'd be race legal. I'm not sure I'll turn it on, as if I can't use it in a race, then I'd prefer not to use it when practicing or else I may not learn how to break properly without the electronics doing some work for me.
I must say, there are some really good articles on MYTSN. In total there are about 3500 articles written since 1999 - I'll skip on the non-english and germans ones, though - although Dutch is almost understandable
Old 06-03-2003, 02:03 PM   #1626
supra528's Avatar
Originally posted by supra528
and now i am 100% sure i am gettin my kit on friday or saturday (prob sat cuz i gotta go see 2fast2furious).... cuz now i got the money... YAY.... is there anything i should get besides the kit?? im not gettin my new radio or engine till i get up to whistler or on the way up there... i know that i should get the kit, one way lube, grease, i have thread lock... umm... should i just get the stuff that it says on the i-manual?? and do i need anything else??and do i need anything else for the battery pack?? and what battery pack should i get??
could someone please help me out??
supra528 is offline   Reply With Quote
Old 06-03-2003, 02:11 PM   #1627
Trader Rating: 2 (75%+)
Cool
You will need a charger for that battery pack.
PUNISHER is offline   Reply With Quote
Old 06-03-2003, 02:26 PM   #1628
markp27's Avatar
The manual covers it, I think. Can't think of anything else I needed - oh, perhaps fuel line to set the break position, as the fuel line included isn't so long as to be able to cut a piece off.
Have you got a glow plug starter? A tool to change the glow plug? Hudy setup station and a MIPS tweak station are nice to have. Lots of tyres and wheels :-)
Cheers, Mark.
Old 06-03-2003, 02:28 PM   #1629
supra528's Avatar
yah.. i have most of the basics there... im gettin the setup stuff in vancouver ... wat about the tool to change wheels... for the wheel nuts... and do i need a piston locker for the engine to put on the flywheel?? and when do i know when to stop turning the pilot shaft??
Old 06-03-2003, 02:33 PM   #1630
markp27's Avatar
Hmm, good question! I can't remember what I used to affix the flywheel! Must have been a small spanner. Just turn it hand tight - not too hard, as you don't want to damage anything. I didn't use a piston locker - you don't need to apply that much force.
To change the wheels I use a 7mm socket.
Old 06-03-2003, 02:35 PM   #1631
markp27's Avatar
I know what it was, it's the tool I use to take the glow plug out. It has 4 different socket sizes: 6mm, 8mm, 10mm and 12mm
Old 06-03-2003, 02:39 PM   #1632
modellor's Avatar
ABS braking is perfectly legal for use here. Like Accord mentioned most high speed digital servos will work fine although there is a company in Germany that produces an actual ABD servo specifically designed for the job. Cant remember the name though.
modellor is offline   Reply With Quote
Old 06-03-2003, 02:40 PM   #1633
markp27's Avatar
As for battery pack: If you can solder, then make one up for your self: I used 750mAh AA cells and got enough to make two battery packs.
Also a charger which can charge your starter box, radio handset and 705 battery pack at the sametime is essential, otherwise it'll take a day for you to recharge everything!!!!!!!!!! My radio handset takes 10 hours to charge (I've got 1600mAh batteries in it), the 705 pack takes 5 hours and I've got two packs, so that's another 10 hours and the starter box has two battery packs which on a fast charge take an hour each.
Money well spent!
Old 06-03-2003, 02:42 PM   #1634
markp27's Avatar
Well I'll be! Right on my door step and I never knew
I've not studied the rules yet, as I won't be racing until the end of the season - what to get more practice in before getting on the circuit.
Which rules are you running to?
Old 06-03-2003, 02:46 PM   #1635
Accord's Avatar
ABS is illegal for racing in ROAR, IFMAR, and nearly every other large organization out there. It is also illegal at most large events that aren't sanctioned by ROAR or another organization.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
