Serpent 705
#1501
WOW! Thanks for the info InitialD!!!!
That was a really clear and informative description there!!!
You couldn't possibly give an explination of what the effects of altering the position of the shock mounting would be, i.e. the differing holes on the front and rear carbon shock bridges?
Is this similar to altering the hardness of the spring (i.e. more upright shocks are like harder springs, more horizontal like softer?) Does the position also affect the weight transfer during breaking/accelerating?
Thanks for the help - one crate of German beer on its way ;-)))))
Mark.
Mark.
#1502
Originally posted by superk
another question about the car..on the Impulse...it seem like it requier to have the rims to be a bit bigger.... than a normal car...will the 705 sterring hup fit all the rims in the market??
Speedmind tires only work in the rear. The front tire rims rub against the knuckles.
#1503
Re: Legal Engines
Originally posted by JABRONI
I guess I am still not sure whay anyone would by a .12 Turbo motor if they are not ROAR legal for competition other than maybe an Outlaw Class.
Seems like a waste of money to me if you are a serious racer then a ROAR legal (Non Turbo) motor is the best way to measure your capabilities against the big boys.
My .12 ROAR Legal NovaMega SX12 RE 3P Race MS is about as good as it gets when it comes to stock ROAR legal engines.
If this forum is for Racers and not Posers, then why in the world would anyone brag about having an outlaw engine when it cant be used in competition in the first place.
I understand it's fun to have a great engine to have some fun with, but when the bottom line is racing and competition , then an outlaw engine is a non factor.
At the recent ROAR region 12 championships, they broke down each engine looking for Ceramic Bearings, Porting , Etc....
Hate to get caught with something illegal, embarassing and wrong.
Most of the time in most races around this region, rules regarding the engine is open as long as it is rated .12. Reason for this is because if they were to limit the engines, they have to have to do tech inspection. Not many people are familiar on how to carry this out.
I am actually not intimidated with the Rodys and the JP engines that I go against... YET. Most of the time I beat people with modified engines with a lowly backyard engine of mine but the times when I loose, I know that it is not the engine that made the difference but the lack of skill which I still need to work upon. So, I am at that stage where I know a modified engine would not help me do better. My engine is fast enough for my level of skill at the moment.
#1504
Mark.
Mark.
Yes, the more horizontal the shock geometry, the softer / more progressive the shocks would be.
Altering the position of the shock (i.e. more vertical or horizontal) is a fine tuning thing. A more drastic way to change the hardness of the spring is to change the spring itself.
If the front shocks are more horizontal than the rear, you get more steering as the front tires will get more traction.
If the rear shocks are more horizontal, you get more rear traction but you loose a little steering.
Of course, the shocks (and hence the placement of the shocks) affect the weight transfer... But I would say that the viscosity of the shock oil affect the weight transfer more. It determines how fast or how slow the weight transfer occurs.
What I usually do on my car is to use a thicker shock oil and possibly a one grade stiffer spring in the front on a one way front diff setup. This is precisely to counter the weight transfer that would occur in the front off throttle. I think it makes the car more stable.
Anyway, I have seen from the setups posted on mytsn by most team drivers and they are putting their front and rear shocks (with red springs and 30wt oil) on the bearing block (old Streetspec setup) without the use of the shock towers. I'm currently trying out this setup but with a thicker oil in the front than the rear. I like the amount of steering that I get from this setup. I would think based upon this experience, the cars that are driven by the team drivers are set up to have a tremendous amount of steering on the car.
#1505
Originally posted by johan
Im back a again to to tell that my 705 is running nice and trouble free. Im very satisfied
btw this tread is like a "q&a" with InitialD. so much knowledge...
As the saying goes, the more you give, the more you receive.
#1506
initiald, how much fuel line (to replace the foam inserts) shd i use in the membranes?
#1507
I don't know. Have not tried it yet. Look at the picture on mytsn and make a guess on the length of the fuel tube base on the picture.
#1508
Just so most of you know, the shocks on the 705 are the same serpent shocks on the Xray EVO II. If you need shock shafts and can't find them in the serpent area, looks for replacements in the xray section.
I'm still deciding between the 705 and the Mugen MTX-3. Sense I race an Xray than the obvious choice to buy is the 705, but I can't make up my mind. I can't make my mind up on an engine either, SX12, SX12 3p race MS or the SX12 5p MS. Are you guys getting good handling from the 705, i know there are loads of setups on mytsn.
#1509
So..where can I get the deal on 705?? after all that read... My impulse pro running pritty good... all the parts from my impulse will fit the 705??? Belt, a armm, up right and turn knockle...most braking parts.
I also....thinking of getting an 705 upgrade kit from Bruckner Hobbie...will it worth the money?? or should I just go get a new one?? any one with any experience with the upgrade kit?
#1510
Polar Movement
nevermind
#1511
The setups posted on mytsn will give you a good starting point. After that, you can by all means fine tune and change the setting according to your liking and your driving style. One man's meat is another man's poison. Most importantly, you need to know the reason why this and that is done to the car. If you understand thos things, then you will be able to tame your car on any track you. This goes for any cars and not just the 705. Perhaps you can also talk to the people who run 705 or the Impulse at your track. They can probably give you a better headstart.
As for the shocks, I know that Xray came out with the same shocks the current 705, 835 and the 950 cars are using. But then I was informed that the shock lengths of the EVO II are all the same unlike on the previous EVO I where the fronts are shorter than the rears. The EVO I shocks are a direct replacement for the Impulse and 705. I may be wrong on this... Maybe somebody else can comment.
As for engines, it depends on what you want. Legal or Outlaw. There are legal modified engines which are very powerful but they are hand modified. Look for the threads on this forum. If you want to play it safe, then a JP modified or the RB Rody tuned engines are your best bet. You pay a price for them though. The Rody and the JP engines are come in legal and outlaw versions. So take note of that.
The MS version of the NovaMega engines are only slightly tuned. Mostly at the carb. I guess their performance is slightly above the normal grade Novarossi and RB engines. But then again, the end result of the engine performance (whatever it is) depends on your tuning skills. A normal engine properly tuned can take a JP or a Rody tuned engine which is poorly tuned.
#1512
The upgrade kit is not worth the money. You do not get the Centax II and the new lightened 2 speed gearbox found on the 705. I don't think there is a rear ball diff either in the upgrade kit. Even Serpent reps from the Holland office commented that they had already stopped making these upgrade kits as they think that it is not worth it and that is the reason why they did not publish it in their products forum.
Better way I think is to sell the Impulse PRO and get the 705 or if you're like me, get the 705 and keep the Impulse PRO as a spare car for parts or if you like as a test car to experiment with different setups, gearing etc.
#1513
Re: Legal Engines
Power without control is nothing.....
#1514
Hope that helps.
#1515
Look on ebay for some good deal on the 705.
