Old 11-21-2005, 04:07 PM   #1
Default Motor Tuning Question....
I have Sirio 3 port 12 and have tried another carburator with no luck...
When I get the engine hot and run it wide open for a couple seconds it seems to 'stick' at half speed then idle down. I have redone the linkages and they are going to neutral fine. I don't think the issue is there becuase even if I hit the brake its still rev'ing.
Any ideas? Thanks!
RCThunder is offline   Reply With Quote
Old 11-21-2005, 04:16 PM   #2
onnetz's Avatar
hard to say from the given info.. what temps are you getting?
sounds like its too lean and detonating..
onnetz is offline   Reply With Quote
Old 11-21-2005, 05:08 PM   #3
RICHEN BOTH NEEDLES TRY TOP 1/4 TURN BOTTOM 1/4 TO 1/2 TURN YOUR RUNNING TOO LEAN. IF TOP END IS FINE JUST RICHEN BOTTOM END TO HELP BRING ENGINE DOWN TO IDLE
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
GFIGUEROA is offline   Reply With Quote
Old 11-21-2005, 06:12 PM   #4
AndyT 's Avatar
Engine losing power as it gets higher in its rpm would indicate that its running too lean (lean bogging)....richen it out a bit.
Cheers
AndyT  is offline   Reply With Quote
Old 11-22-2005, 08:52 AM   #5
Thank you for your help!
Old 11-24-2005, 10:06 PM   #6
Trader Rating: 13 (93%+)
this actually sounds like the clutch is grabbing
is this a centax style clutch ?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 11-25-2005, 01:28 AM   #7
FF25510's Avatar
did you put on the O-ring between the carburator and the body?
FF25510 is offline   Reply With Quote
Old 11-25-2005, 01:48 AM   #8
Default Exception to every rule!
I agree with everything that was said above, but believe it or not, being excessively rich on the Low speed needle can also lead to an engine running on. If rich on the bottom end, rpm decreases & engine will stall. To combat this, some people turn up the idle on the carby (screw it in). As you come off the throttle, the engine still has a belly full of fuel and due to the idle screw (on the carby) keeping the throttle slightly more open than usual, this causes the eingine to run on.
The solution would be to return the carby to factory settings, adjust your trim on the radio, set your gap (throttle opening) to 0.5mm with the idle screw. Then you start tuning at the top (High speed needle), then the bottom (low speed needle) for response off the line, then adjust the idle accordingly.
p.s. I was told this by the Australian 1/8th scale champion last weekend,and he also demonstrated it to me. I had the exact same problem with my N12LL3.
Im not saying that this is definately the problem with yours, but its worth a try.
Hope this solves your problem!
Rody is offline   Reply With Quote
motor tuning question.... SteveJa Nitro Off-Road 10 12-31-2007 12:01 AM
Tuning Question ChrisE Electric Off-Road 3 05-21-2007 05:49 PM
SH .28 Tuning question Nickmind Monster Trucks 3 04-13-2006 09:47 AM
beginner questions re: car tuning and motor tuning! Captjono Rookie Zone 5 02-19-2005 12:01 PM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
