Old 01-20-2006, 10:51 AM   #121
Default thanks
Thanks JLock and EcZahst1. Would it be smart to always heat the engine up before you start it? Or after break-in would it matter anymore? Thanks
RobertM is offline   Reply With Quote
Old 01-20-2006, 11:05 AM   #122
JLock's Avatar
I did not preheat mine and it fired up right away. But, it all depends on what you feel comfortable with. But just remember, don't start pushing the engine hard until around tank #7 and even then, not too hard until after that tank.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 01-20-2006, 12:26 PM   #123
Alright... Thanks for the tips JLock
Old 01-20-2006, 02:50 PM   #124
Default break in
I used the hair dryer for the first and second tanks, then it started without it after that. If your able to start it without right off the bat, thats great, mine would'nt budge...!Starter wheel just sat there and smoked...!
EcZahst1 is offline   Reply With Quote
Old 01-21-2006, 06:14 PM   #125
AndyT ©'s Avatar
Mine was VERY tight.......just loosened the plug off a fraction and it turned over without too much hassle. Just remember to tighten the plug back up when its idling
Cheers
AndyT © is offline   Reply With Quote
Old 01-22-2006, 07:05 PM   #126
Rey
Rey's Avatar
Carburetor
Does anyone know what to do with the carb popping off? Iíve replaced 2 Teflon sleeves already but canít seem to find the fix. When I replaced the sleeved and tightened the nut too much it cracks it but when not tight enough the carb is loose. Any suggestions before sending it to Hobby Services? Thanks
Rey is offline   Reply With Quote
Old 01-23-2006, 03:36 AM   #127
BrainTeased's Avatar
Add abit of sealant compound such as automotive silicon.
i've also tried with a smear of grease around the carb body with good results as i had no sealant lying around
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-24-2006, 12:40 AM   #128
ChApS's Avatar
Does any one know if o.s engines are releasing a new engine soon. As im plannig on getting a o.s TZ
ChApS is offline   Reply With Quote
Old 01-24-2006, 12:42 AM   #129
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Dont think they will or should. I mean, they hit the jackpot with the OS TZ. $190 engine with a rebuild under $80. Just remember that youll need to gear up your car, OS Engines as well as Rossi engines are known for their amazing torque.
Riketsu is offline   Reply With Quote
Old 01-24-2006, 01:22 AM   #130
AndyT ©'s Avatar
Yes....thats one thing thats really impressed me with the OS TZ and Skyline VR12 pipe, is its abundant torque across the power range
Old 01-24-2006, 07:37 AM   #131
gijoe64's Avatar
Trader Rating: 30 (100%+)
OS does not have plans on releasing any new .12 engines.
gijoe64 is offline   Reply With Quote
Old 01-24-2006, 08:33 AM   #132
hardrider's Avatar
Trader Rating: 39 (100%+)
Don't ask how but I lost the metering needle assembly (#21538500) for my TZ12 T5
LHS has no stock as apparently I'm the only fool in town who lost it
I will have to wait for the next order date which could be months away.
Any idea where I might be able to pick one up? Somewhere with ready stock and will ship internationally.
hardrider is offline   Reply With Quote
Old 01-24-2006, 10:15 AM   #133
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Wink
There are different OS.12TZ modified motors on the market that are new that you might want to try.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-24-2006, 02:47 PM   #134
any links to these diff. modified motors, to see if one is possibly better than the other?
bosfan is offline   Reply With Quote
Old 01-24-2006, 06:35 PM   #135
ChApS's Avatar
http;//www.osengines.com/engines/osmg1995.html
