Old 01-02-2006, 06:15 PM   #91
Originally Posted by Rody
If you want an OS pipe, the OS 1040 is supposed to work well with the TZ. Others seem to like the Skyline VR12. I personally prefer the Mugen EFRA 2501 pipe. My TZ is insane with this pipe. It's the fastest i've tried but fuel consumption suffers a little.
I have both 1040 and VR12. I like 1040 better in terms of performance and quality, but VR12 is cheaper
silverM3 is offline   Reply With Quote
Old 01-02-2006, 09:49 PM   #92
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hello, what glow plug are you guys running with your TZ ? i know there are only certain brands will work with TZ and just to be safe i bought 2 dozen of OS P3 ultra hot plugs , has anyone running this plug ? I have been running medium sometimes medium hot in my nova based engines but never run a hot plug let along ultra hot, i only bought it because the hobbyshop where i purchased the enigne recommmend, he said OS TZ works best with hot plug..what do you guys think ?
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 01-02-2006, 09:54 PM   #93
Tag
Tag's Avatar
i was debating if i should go with RD turbo 3 or just bite the bullet try the OS 1040, i have been running RD turbo pipe in my nova based enignes and has had good experience with them. I ended up bought the OS 1040 just want to try something different, pipe looks good can't wait to see how it runs
Old 01-02-2006, 10:08 PM   #94
jca2000au's Avatar
Trader Rating: 9 (91%+)
Hi...Tag
Are you sure that you brought "P3"? As far as I know TZ is running on Turbo plug and Turbo plugs range are P6 (Hot), P7 (Medium) and P8 (Cold).
Please check on the link http://www.os-engines.co.jp/english/...g/pluindex.htm
jca2000au is offline   Reply With Quote
Old 01-02-2006, 10:18 PM   #95
Tag
Tag's Avatar
Yes these are P3 ultra hot turbo plugs as found on
http://www.osengines.com/accys/glowplugs.html
Old 01-03-2006, 03:09 AM   #96
foampervert's Avatar
Send a message via MSN to foampervert
Default plugz.....
hiya Tag,
for a .12 sized engine, it doesn't really matter if you use the P3 plugs... as long as your nitro level is not extreme( >30%)... as a matter of fact, i am running a Zac modefied TZ12 with only 0.3 mm shim, P3 plugs, 30% nitro..... it runs beautifully with no detonation. i have fabulous idling and i can turn down the idling screw to insanely low settings and still get a snappy response to full bore, and i live and race in the hot humid tropics.
the best indicator of whether you are using the right plug is color, "wetness" and condition of the glowplug right after a run. make sure the coil is not distorted nor charred. the area around the glowplug CAN be darkened but the wire should be slighty greyed or shiny still.
also check to make sure that the piston top is not chipped as this is an indication of detonation.
have fun!
-alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 01-04-2006, 08:39 PM   #97
Trader Rating: 13 (93%+)
hey mate how do u like the zac modified tz ?
im thinking of either buying that or the 5 port tz
we are allowed to use any .12 engine in our races over here
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-05-2006, 09:44 AM   #98
Default Zac modded OS Tz12
hiya Mrgsr!
i am using the 5 port version cos the 3 port is not available here in singapore( we dont believe in 3 porters)
it has more oomph then the regular 5 porter for sure, seems to idle just as well( maybe cos i use 30% nitro)
the crankshaft is lightened and epoxied, an extra turbo cutout is done on the right side of the crank pin.
the sleeve looks more like a novarossi sleeve
and of cos, all black anodising and Zac heatsink head.
i mate it with a Zac 6mm pipe, which is pretty good, i am thinking of trying a 6 mm pipe from sage racing, it has awsome power at all rpms.
-alexander
Old 01-05-2006, 11:51 AM   #99
ziggy12345's Avatar
Where can I get the ZAC modified OS engine?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 01-05-2006, 02:39 PM   #100
Send a message via AIM to jeff whiting
The ZAC OS is available on the Kawahara web site.
JEFF
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 01-05-2006, 03:12 PM   #101
ziggy12345's Avatar
You can buy it from there? Or another site?
Cheers
Sponsored by:
Norfolk and Chance
Old 01-05-2006, 08:07 PM   #102
Cheers
Ziggy12345 thats a good question. I looked at the site closer and I can't really tell if you can order direct from Kawahara or not. Too much Japanese (or whatever it is) for me to make it out. I like would like to try one of these Zac's Project TZ's because the stock TZ runs very strong. Anyone else out there know???
JEFF
Old 01-06-2006, 04:06 AM   #103
ziggy12345's Avatar
Ishiimokei. Co. Ltd. [[email protected]]
I emailed this guy who said he would try to get hold of them. If you send him a mail it will show others are interested which might spur him on
Cheers
Sponsored by:
Norfolk and Chance
Old 01-06-2006, 04:21 AM   #104
ZAC OS 12 vs ORG. OS 12 with pic
http://www.rcstudy.com/forum/viewtopic.php?t=1832
A380 is offline   Reply With Quote
Old 01-06-2006, 04:26 AM   #105
Cheers
Either 3 port or 5 port ZAC OS 12TZ engine.It is easy buy in HK.
As I know it cost about US$260
