Old 10-30-2002, 08:30 PM   #46
Send a message via ICQ to V-One S
well the NTC3 has no engine i it.
Nothing to allow it to go forward.
Where as the V-One S has an engine in it standard that can be replaced later.
V-One S is offline   Reply With Quote
Old 10-30-2002, 08:39 PM   #47
Ahhh
I thought it was motor as in electric car.
I thought the NTC3 is RTR.
darthkir is offline   Reply With Quote
Old 10-30-2002, 08:40 PM   #48
asd
Send a message via ICQ to asd
it comes as a kit and rtr
asd is offline   Reply With Quote
Old 10-30-2002, 08:43 PM   #49
no the NTC3 u have to build it.
Old 10-30-2002, 08:55 PM   #50
What about my tyre question. Appreciate if you guys could help
Old 10-30-2002, 09:02 PM   #51
Dont ask me about rubber and foams i dont know much on them, i'd prefer rubber cause ppl i've talked to say that foams u have to keep them trued and everything, but half our club runs rubber.
Just depends on the surface.
But i dont know much on the rubber foam debate.
I only thought the NTC3 came as a build it yourself i never knew it was an RTR as well.
I just heard kyosho is bringing out a new V-One S,
Its called the V-One S Racer. because everyone was doing the rear floating pod conversion kyosho is releasing some time in november (should be in shops by then) the V-One S with the floating rear pod, so they can get in on all the sales now eve more.
Old 10-30-2002, 09:06 PM   #52
Go here it has stuff on tyres
Tyres.
Old 10-30-2002, 09:24 PM   #53
Wow
What is the rear floating pod conversion?
Old 10-30-2002, 09:27 PM   #54
The rear floating pod conversion is a style of how the V-One RR has its body mounted, instead of the body posts coming from the bulk head or some where alike, it comes from a piece that screws directly to the hub carrier so that down force is given directly to the rear wheels in stead of to the chassis and lost in the suspension.
Its a huge benefit to rear down force every one has told me,
its a $40 conversion for it.
Old 10-30-2002, 10:30 PM   #55
ChrisO's Avatar
Send a message via AIM to ChrisO Send a message via Yahoo to ChrisO
hey V one-S the idea of rear pods sounds sick. i wish i could get one for my ntc3
ChrisO is offline   Reply With Quote
Old 10-30-2002, 11:53 PM   #56
I see
Hey, do you have a pic of the rear pod conversion?
Old 10-31-2002, 05:46 AM   #57
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
The NTC3 is a KIT and a RTR, but i am not sure of the availibility of the RTR overseas
myclod is offline   Reply With Quote
Old 10-31-2002, 08:01 PM   #58
Chris u should be able to adapt one for your NTC3 if u really put ya mind to it.
Hopefully i can get to a race meet again.
Really wanna get the car toa meet again soon.
Old 10-31-2002, 09:02 PM   #59
Foams are great on prepared surfaces, sprayed with sugar water.
They will hook up great. Otherwise they slide around a bit. A very controllable slide though on unpreped asphalt.
I have no track in my area that preps the track. SOoo I use rubber tires, 24mm HPI Advans, 33r with HPi Green 24mm inserts.
Or Ofnas K-1 slick on Ofnas Hyper rims, with HPI red 26mm(firm i think) inserts. The Advans have some tread so they chew thru the dust and debris on the asphalt. Ofnas K-1 have no tread but on a cleaner surface they can rock.
Foger Rox is offline   Reply With Quote
Old 10-31-2002, 10:17 PM   #60
Im2lazy's Avatar
From my experience with OFNA rims, I think that they kind of suck hard. . One guy tapped the rear quarter of my car and the rim cracked! It wasn't a small touch, but I've seen my cars come clean out crashes in that same position even with a harder impact. Maybe I had a bad set of Eight rims, but I cracked 3 of 'em in three race days, and I've seen others complain about how flimsy and brittle they are.
How have they been for you?
Im2lazy is offline   Reply With Quote
newbie questions gymfreek69 Monster Trucks 1 10-04-2007 08:28 PM
Newbie Questions FastFritz Nitro On-Road 3 09-03-2006 06:14 PM
NEWBIE questions jasonctx Malaysian R/C Racers 47 10-20-2005 05:47 AM
Newbie questions ANGST Rookie Zone 3 06-25-2005 01:42 PM
Newbie Questions? e420x Painting, Designs, Graphics and Photography 1 08-07-2004 01:16 AM
