Old 11-08-2005, 01:46 PM   #1
Default Engine wont start...need help !! thank you
Hey guys !! totally new to this sport...just bought a Kyosho FW-05T
bought some 10% nitro fuel....
did everything stated on the instructions...
engine started up once...but died....now it doesnt start up
i have no idea why...ive done everything as stated...
i have a feeling it is the glow plug...i charged it for a whole night...but when i insert it into the top bit it isnt hot i dont think...instructions say its spos to glow red when you take it out...
any suggestions guys ??
thanks
much appreciated !!
alexlai50 is offline   Reply With Quote
Old 11-08-2005, 01:58 PM   #2
Derby Bros Racing's Avatar
install a fresh glow plug.
if you have the instructions manual, put back the needle setting to factory and start from there. if you don't, try researching the forums or internet for your particular engine's factory needle settings.
good luck
Derby Bros Racing is offline   Reply With Quote
Old 11-08-2005, 02:40 PM   #3
JABRONI's Avatar
Default Come on JO !!
good luck
You trying to get to a 1000 posts the easy way or what ????/ ROFL
GLow Plug ????? Could Be !!!
Could be several things, Air leak in tubing, To lean of set up, etc.....
From your post I am assuming that you mean you actually took the glow plug out of the top of the engine to check it.
You stated you charged you glow plug all night, I am assuming you mean your glow plug ignitor (Tool) and then checked to see if the red coil on the bottom of the "Glow Plug" is red, not the tool end.
If all is well then take off your air filter and try putting your finger over the exhaust hole of your exhaust pipe and then try to start it to make sure that fuel is entering your carbuerator.
If all is still well, then try a new glow plug as JO stated ROFL !!!!
Good Luck
BY the way, what type of engine is it ???
JABRONI is offline   Reply With Quote
Old 11-08-2005, 02:44 PM   #4
HAHAHA
i've been trying really hard j/k
try a new glow plug. it won't hurt. and if just in case you didn't need it replaced, put it in your box as a spare, because you will definitely need it in the future.
Old 11-08-2005, 07:31 PM   #5
vulso's Avatar
I don't know but 10% nitro fuel? Seems a little low on Nitro content.
vulso is offline   Reply With Quote
Old 11-10-2005, 07:47 AM   #6
sexy_foxgurl69's Avatar
Send a message via Yahoo to sexy_foxgurl69
have u tried just flushing it out and trying again????\
that might work had the same prob with my trail 70 and i just flushed everything and put new everthing else in it and now it runs like a dream
sexy_foxgurl69 is offline   Reply With Quote
Old 11-10-2005, 03:26 PM   #7
BYGBLU21's Avatar
Put a new glow plug into a fully charged glow plug igniter and it should glow red. If it does and your engine still will not start check for fuel flow. First off, and it may sound stupid but i've done it, make sure the fuel cut off clip is not squeezed. Cover the outlet on the exhaust and crank it a few times. If your finger gets a little fuel on it you have fuel flow. You may still have a leak but it should not be enough to keep it from starting. Hope this helps a little.
BYGBLU21 is offline   Reply With Quote
Old 11-10-2005, 03:36 PM   #8
JABRONI's Avatar
Default ????
Pretty sure thats about the same thing I said in post #3 !!
Old 11-11-2005, 09:18 AM   #9
hi guys....engine started at last....
i dno wt was the problem...i adjusted the needle very slightly and the glow plug was fine loL !!
neways thanks for the help !!
appreciated....
ENGINE WONT START??? Roadrash730 Onroad Nitro Engine Zone 3 01-28-2008 10:47 AM
Engine wont start help! Hpimichael Nitro On-Road 5 03-01-2007 11:03 PM
trx pro. 15 engine wont start, need help... 72skylinegs Onroad Nitro Engine Zone 2 10-09-2005 01:44 AM
engine wont start 2mcgrath Nitro On-Road 3 10-06-2003 10:21 AM
Engine wont start dvargas Nitro On-Road 1 04-26-2003 11:17 PM
