Like Tree142Likes
Mugen MRX6
Old 03-29-2020, 03:12 AM
  #1126
Mugen:
1st gear pinion: 19 20
2nd gear pinion 24 25
1st gear spur 60 61 62
2nd gear spur 56 57 58
ARC:
1st gear pinion: 17 18 19
2nd gear pinion 22 23 24
Infinity:
1st gear pinion: 19
2nd gear pinion 24
And there are the differences, mugen has larger pinions but by default it comes with th same gearing as the others.
The default 2nd gear ratio with mod 0.8 is like running 20/47 with mod-1 gears. To me not very uncommon but not what you want on larger tracks.
I' m using arc gearbox with 0.8 mod on my mrx6r, the only difference just said Roelof is that I have to use different gearing compared to arc- infinity. Mugen gearing will be similar to shepherd, who use 48 pulley like us. I tested it for a year on two car, it works pretty well.
pasqua2291 is offline
Old 03-29-2020, 03:57 PM
  #1127
Kevin CBR's Avatar
Looks good YoDog. Looking forward to seeing you back down at Steel City once it is able to open up. First weekend is going to look like a bunch of crack addicts just released from rehab. :-O
Kevin CBR is offline
Old 03-29-2020, 10:34 PM
  #1128
YoDog's Avatar
Trader Rating: 28 (100%+)
LOL...Crack head right here!
She went together like a dream. The only issue I had was a slightly warped front lower arm. The hinge pin was a bit tight and wouldn't move freely. The other side was butter. The logic of how some parts were bagged didn't make much sense to me but I've built my share of kits and figured it out no problem.
YoDog is offline
Old 04-03-2020, 07:18 PM
  #1129
choisan's Avatar
may i know how is the metal handle of 6x in different to the previous, it has different number. also is the bronze taper cone for engine new to 6x only?
choisan is offline
Old 04-03-2020, 10:08 PM
  #1130
YoDog's Avatar
It's a bit wider at the top and possibly a little taller.
They probably included the new tapered cone for better fitment of the 4 bearing clutch. IDK as I didn't have the earlier kits new.
YoDog is offline
Old 04-03-2020, 10:22 PM
  #1131
choisan's Avatar
i checked from the 6r manual, the taper cone didn't exist
choisan is offline
Old 04-03-2020, 10:55 PM
  #1132
YoDog's Avatar
Yeah, I didn't think so. I suppose enough people complained about the poor fit with the novarossi cones. Although the Mugen cone was available as an option, people weren't happy that they had to buy a special cone to use their engine of choice.
YoDog is offline
Old 05-04-2020, 08:03 PM
  #1133
1/8 IC Fan's Avatar
Trader Rating: 95 (100%+)
MSE new Body mount. Carbon fiber.
1/8 IC Fan is offline
Old 05-04-2020, 08:50 PM
  #1134
YoDog's Avatar
Well that is nice looking. I'd hope it could handle some abuse.
YoDog is offline
Old 05-05-2020, 01:42 AM
  #1135
Roelof's Avatar
It must be 3 or 4mm carnon to withstand a hit. Looks nice but if the weight difference is only a few grams then it is not worth the 50 euro....
And how to attach a deer antler most people use to stiffen up the body?
Roelof is offline
Old 05-05-2020, 04:23 AM
  #1136
ralphierace13's Avatar
exactly !! this thing will crack too easy...
ralphierace13 is offline
Old 05-05-2020, 05:33 AM
  #1137
Pooh2's Avatar
Just buy it Ralph. You won't crack it.
1/8 IC Fan likes this.
Pooh2 is offline
Old 05-06-2020, 09:14 AM
  #1138
YoDog's Avatar
It's likely at least 5mm thick but I agree, not worth 50 euro for what little performance it may add due to it's stiffness. All chassis Mfrs. make the OE body mount from softer/flexible material for good reason. If stiffness was truly desired, they would make it from the same plastic as the arms. Knowing it would be subject to impact, it is not stiff on purpose.
The top mounted body stiffener might still fit but...
YoDog is offline
Old 05-07-2020, 05:13 AM
  #1139
They should of made the ends so u can put the adjustable body screws in .. oh well
Old 05-09-2020, 04:45 PM
  #1140
Grenade10's Avatar
Trader Rating: 40 (100%+)
Width at the top is wider ….. Old one you could fit two fingers, now you can fit three
Grenade10 is offline
