Like Tree74Likes
Mugen MRX6
Old 06-10-2019, 10:16 AM
  #871
sinisterRC's Avatar
Originally Posted by ralphierace13 View Post
No the bumper does not hold the body up, but if its warped change it, if its rubbing it will cause the car to push.. Important is how far off the bumper you are mounting the body? If its too far forward no matter what you do the downforce will cause it to hit. Another thing I do is I leave a hole open in between the bottom pin and the top pin so its not pressing it down to tight. also check a lot of times the body is hitting on the sides in the front between the corner of the front to the wheel well..
Interesting info regarding the body mount hole on the post. Would it be beneficial to have a washer to space it up a little?
I will pay close attention to how far I mount the body from the bumper, must have mounted way to forward.
sinisterRC is offline
Old 06-10-2019, 10:20 AM
  #872
Roelof's Avatar
Yes, you do need to fill it up, w/o a washer the body will for sure sit too low.I did cut out a piece of rubber from an old rear tire to make the spacer.
Roelof is offline
Old 06-11-2019, 08:30 AM
  #873
sinisterRC's Avatar
Thanks for the help, how many holes (from the bottom up) should I be at? 2?
Old 06-11-2019, 09:45 AM
  #874
Roelof's Avatar
My spacer comes until the 1st hole
sinisterRC likes this.
Roelof is offline
Old 06-14-2019, 12:04 PM
  #875
Jed
Jed's Avatar
Could you advise whether the MRX5 and MRX6 used the same pulley gears? I have looked at the diagrams for both and they do look similar but noticed they both had different part numbers by Mugen.
Jed is offline
Old 06-14-2019, 12:49 PM
  #876
Roelof's Avatar
The 20T brake pulley is different but on the MRX6 the MRX5 pulley can be used if you use the MRX5 lockup ring
And the 48T rear pulley is different but if you make the slot for the 3mm pin on the MRX5 pulley a little bit deeper it will fit the MRX6
The rest will fit
Roelof is offline
Old 06-14-2019, 05:40 PM
  #877
Jed
Jed's Avatar
The rest will fit
thanks Roelof!
Jed is offline
Old 06-16-2019, 04:14 AM
  #878
Jed
Jed's Avatar
surge tank
Aluminum servo saver
Something I decided to do on my MRX6 mainly becoz I had nothing better to do 😂
Jed is offline
Old 06-16-2019, 01:49 PM
  #879
ralphierace13's Avatar
hey jed thanks for the pics, hey if your using a pressure tank u dont need long hoses u should mount the pressure chamber where the hole is for it,.,. jmo
ralphierace13 is offline
Old 06-16-2019, 01:57 PM
  #880
Roelof's Avatar
He is just cheating on his fuel capacity......
1/8 IC Fan likes this.
Roelof is offline
Old 06-16-2019, 07:55 PM
  #881
Jed
Jed's Avatar
Have not tested if it gives you a few more seconds per tank but it does make your setting a bit leaner than if you had a hose connected directly from tank to engine. Did about three tank test and I noticed that difference. Am assuming because of the system the pressure is slightly less hence less fuel flows to the engine making it leaner?
Jed is offline
Old 06-16-2019, 10:59 PM
  #882
Trader Rating: 16 (94%+)
Hey guys, I have MRX6R new in the box with new parts to sell if anybody's interested. PM me.
snuvet75 is offline
Old 06-23-2019, 08:58 AM
  #883
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
PM sent
GrandeGixxer is offline
