Old 11-23-2005, 03:17 PM   #46
reactor's Avatar
Originally Posted by Motorman
I will confirm it for you as fact.
that was very promising...cant wait for the S to hit shops
reactor is offline   Reply With Quote
Old 11-23-2005, 03:20 PM   #47
Motorman's Avatar
It will have much more than you expect.
gone will be these issues.
rear shock tower issues
clutch issues
steering issues
belt issues
gear issues
plus more.
I'll let you put it together as to what it will have as I am sure you have seen K factory parts to improve alot of this.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 11-23-2005, 04:15 PM   #48
reactor's Avatar
clutch issues
steering issues
belt issues
gear issues
plus more.
Thats a total improvement! worth to have a 2nd car,thanks Motorman for the great news.
Old 11-24-2005, 02:11 AM   #49
Bundy_Bear's Avatar
Originally Posted by Car Breaker
steering don't return? (never have that problem from my G4-E or Mongoose
I bet it is the problem of your servo
Never have sliiped clutch in both, rechech teh setting of your clutch
I have excellant break (too much break) and never drag or no break, same word, check your setting, the two screw that hold the break pad
Don't bedisappointed with TM, their car is good, just spend a little time examine the car, most of time, those symptom you mention is more due to the skill of assambly
Car Breaker:
You are a tool if you think the problems i had with my G4 12mnths ago were because of the user. If this is your thinking, maybe you can explain to me why we have seen three different steering systems and three different types of Centax clutches?????
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 11-24-2005, 03:09 AM   #50
ogreasurada's Avatar
Originally Posted by Bundy_Bear
Car Breaker:
BB
So you can crash the car in total 9 different combos.... j/k
I guess the options are probably opted for different track layouts and driving styles.
ogreasurada is offline   Reply With Quote
Old 11-24-2005, 04:39 AM   #51
Car Breaker's Avatar
Car Breaker:
BB
First of all, I am not a "tool" nor you are in any position to judge my intelligent.
3 steering systems and clutches to me are for personal preference. at least I have no trouble with both rail and swing type steering, my car run straight.
and I don't have issue with clutch nor break
Having 3rd generation of clutch not neccasary mean the previous version is bad, it just mean not perfact which perfaction is very difficult to achieve.
after repair many cars in my LSH, I noticce that yes there might be so imperfaction in design or product quality, however I do see many people having issue with their cars not because it is faulty product but their skill to build and maintain their ride. I do not mean that I have perfect skill, I will never have perfect skill.
I don't know how close your building skill to perfection, mine definatly far. if a lousy person like me have no problem you should be able to overcome the problem on your knowledge.,
one things that is fun about RC is to make things works. don't you think so?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 11-24-2005, 05:05 AM   #52
talking about G4 S, what will include in teh convertion kit if there is any?
Xray X12 2015
ARC R10 ATS
Old 11-25-2005, 03:03 AM   #53
Bundy_Bear's Avatar
Righto... as you and your Mongoose are still wet behind the ears i will let you enjoy being on cloud nine for a little longer.
Good luck with your Mongoose! I will keep a watchful eye on the progress of the G4 S and you never know what happens in the future
BB
MissMooRC Racing
Old 11-26-2005, 02:10 AM   #54
BB
let me state it clearly:
(never have that problem from my G4-E or Mongoose)
the "G4-E" mentioned above was the first generation, and now I get a new Mongoose, so I am not new to G4
I will enjoy my Mongoose
please feel free to get what you think is good
Xray X12 2015
ARC R10 ATS
Old 11-27-2005, 10:46 PM   #55
Trader Rating: 44 (100%+)
these are some problems i encountered:
1. weak chassis - i had the original metal-stamped stock chassis. doesn't require a big hit to warp easily. (ok .. driver's error!!)
if u have the tough KFactory ones <- they are indestructible.
2. leaking KFactory fuel tank
- i upgraded the stock fuel tank to the KFactory one.
- after a number of races, noticed that the area on the upper radio deck was always wet with fuel. so i did the bubble test , by immersing it under water. pretty shock to see it leaking!
- the stock G4 tank did not leak though
- so i'm back to using the stock, albeit smaller, tank
3. flywheel
- the original G4 thread contained discussions on this
- i had the exact same problem as highlighted by other G4 owners (the 3-pc centax flyweight getting stuck on the edge of the flywheel) - resulted in a slipping clutch
- many pple, including Motorman, recommended a simple fix of filing the edge of the flywheel. it worked a treat. but required trial and error to get the correct amount of material to file away.
4. stripped rear belt when a pebble was stuck (again .. my error for running it on a netball court!)
- replaced it with a V1R belt as recommended by some drivers
- the V1R belt looks twice the width of the stock G4 belt! it looks really, really tough!
apart from the above, i think the G4 is a great value for money.
i'm still racing mine and more than happy with it.
ps - the original G4 thread had tonnes of good info about weaknesses & work-arounds.
wyl03 is offline   Reply With Quote
Old 11-27-2005, 11:42 PM   #56
Motorman's Avatar
with the release of the new car you will see quantum leap improvements.
Old 12-09-2005, 04:07 PM   #57
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
Default R40 vs G4?
im am about to purchase a new race project for the 2006 season. I have narrowed it down to the R40 and the G4. What do you yall think? Pros and Cons? Where can i purchase a new G4 S?
badKarma is offline   Reply With Quote
Old 12-09-2005, 04:18 PM   #58
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Go for the G4 but wait until January 2006 for the S version,
cya !
Pat
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 12-09-2005, 05:46 PM   #59
definately G4, wait for the S at Jan 2006, R40 is good car but you need more hop-up on it except you get the HARA edition which is so much pricier.
but the real concern is the source of parts, get what you can get parts for, still I am happy with G4
Xray X12 2015
ARC R10 ATS
Old 12-09-2005, 08:15 PM   #60
Motorman's Avatar
Bad Karma contact C whits up in maryland he can help you. The S will be available soon.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4 Evo??? llamont Nitro On-Road 5 03-29-2007 12:44 AM
Team Magic G4S RTR - The Joy of Driving (part one) ME rcforum Nitro On-Road 3 12-06-2006 03:02 PM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
