V-ONE RR thread
Im new to this forum and im quite a newbie on RC.....
I owned a v-one s (going to sell away) n bought a v-one RR recently. I haven't bought the engine n considering nova 5 port or the sirio outlaw...maybe u guys can give mi advice.. BTW, the main reason i post here is i hope to see u guys posting ur own v-one R/RR pics n list down the modification if possible. Thanx!!!! :smile: |
1 Attachment(s)
nothin....:(
let me ask you, what is the difference between the V-one-R and the V-one-RR? All I really noticed was a centax clutch, rear body mounts and the new front lower plastic bumper. otherwise, it seems like the foam equipped VoneR with the choice of rubber slicks or foams.
This has been nagging me for a while. |
Differences being:
1. Wide front bumper and body mount (for VDS / Lola body) 2. Front one way 3. Rear floating body mount 4. Rear 30mm tires 5. Centax clutch Correct me if I missed anything :nod: Originally posted by Im2lazy let me ask you, what is the difference between the V-one-R and the V-one-RR? All I really noticed was a centax clutch, rear body mounts and the new front lower plastic bumper. otherwise, it seems like the foam equipped VoneR with the choice of rubber slicks or foams. This has been nagging me for a while. |
For the Lola equipped V One RR the differences are as follows.
-adjustable blade type front swaybar. -new wide bumper -new front body mount -new belts (all three are different from the V One R in terms of material) -RR side belt is smaller than the V One R belt. -overdriven front (25T pulley) -new rear bulkhead brace -new rear shock towers -centax clutch -rear floating pod body mount -26mm foams front, 30mm rear -shorter rear dogbone & longer rear axle There are other few minor differences, but these are the biggies. |
Which V-One R is it that has the wider rear track?
I dont know if the Stratus RR has 30mm foams for the rear, but i do know that the Lola has 30mm foams. The cars are all 200mm, so there is no difference in width.
Well one of them has a different rear track width.
don't know if it is wider or thinner |
Thanks. To me, I still don't see it as much of a difference as some of that stuff was on the grp voner.
But I think coming out with this car is better than revamping the whole car the way that Manufacturers have been known to do before anyone really had their cars for any period of time. (cough...serpent...cough...veteq...cough) This way, owners of the wold car can revamptheir racing platform, if they don't already have most of this stuff anyways.:p |
There are ome major changes in there that would cost a few $$$ to upgrade on the V-One R so yeah they just brought out a diff V-One R called the V-One RR,
The best things they improved between the RR and the GRP was including a centax type clutch and also an adjustable blade type swaybar for the front. Also the overdriven front is a welcome addition since the car has a oneway. the floating rear pod is the most useful when using lola/can am type bodies IMO.
what is the floating rear pod and wat does it do?
design found mostly in 1/10 and 1/8 onroad cars. the idea stems from the problem that downforce is wasted by compressing the suspension and in some extreme cases compressing it to the point where the chassis scraps the ground. to solve this they linked the rear hub or rear camber link to the body mount so that the downforce "pushes" directly or indirectly to the hub so the downforce from the mounts reaches the wheels.
O ok, i see now
Originally posted by icon design found mostly in 1/10 and 1/8 onroad cars. the idea stems from the problem that downforce is wasted by compressing the suspension and in some extreme cases compressing it to the point where the chassis scraps the ground. to solve this they linked the rear hub or rear camber link to the body mount so that the downforce "pushes" directly or indirectly to the hub so the downforce from the mounts reaches the wheels. |
| All times are GMT -7. It is currently 02:11 PM. |
