Old 10-22-2005, 09:13 PM   #1
06
Default DX3
Has anyone out there try this radio?how is it compare to Futaba 3PJS/3PK or Sanwa M8/M11?
06 is offline   Reply With Quote
Old 10-23-2005, 04:47 AM   #2
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
It has spektrum which is good, but it's features is the same as a Futaba 3PDFX. All other radios you mentioned have far more advanced and more options for fine tuning. If you don't need all the other adjustments and just want spektrum that radio is great. I plan on buying one some time later on.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 10-23-2005, 05:18 PM   #3
06
thanks for that valueable info dude.
Old 10-23-2005, 05:59 PM   #4
OnRoad-Racer's Avatar
Send a message via AIM to OnRoad-Racer
I used the Spektrum DX3 for a total of 3 weekends before getting rid of it. It is a very BASIC radio. There are minimal adjustments on it (basics). No Exponential, no ABS, Traction Control, etc ... All the things that are in the other radios you mentioned. In a nutshell, this is the JR XR2 radio with a spektrum module in it. Even the servos are rebadged JR servos.
I do race my car competatively and this radio didn't have what was needed in my situation as far as adjustments were concerned. I would suggest passing on this radio if you are in to organized racing. If you run in the park and mess around with friends, then this is the radio for you.
OnRoad-Racer is offline   Reply With Quote
Old 10-24-2005, 09:52 AM   #5
06
thanks a lot dude.i'll take your advise.is there a spektrum module for 3pjs.i'm using this radio and really like it a lot but the problem is,there is a few players at my local track using the same freq.
Old 10-24-2005, 08:46 PM   #6
As a matter of fact YES there is a module for the 3PJs. Only reason I know is because that's the exact radio that I am using The module used for the futaba 3PK an 3PJS is the same. Just make sure that when you install the module, it is in the PPM mode instead of PCM.
