Old 10-16-2005, 12:50 AM   #1
Default setup issue
i got a g4 and the current setup im using works best with 37 front and 35 reaer tires but these tires wear out too quickly.what can i do to the car to get the same feeling but with 40 front and 37 reaer tires????
could i go softer on all four springs to make the car softer overall ??
any help would be appreciated
g4raycer is offline   Reply With Quote
Old 10-16-2005, 04:00 AM   #2
Registered User
xrcbuggy's Avatar
You said it yourself, go softer on springs & more droop, but you have to consider the track too. the 1st thing I would do is to take the front & the back anti-roll bars out, put 40 tire in front & 37 in the back & test it on the track which you have plan to run it. My car runs alot better on a small track w/o anti-roll bars & I use 40 all around.
Please visit RDlogics Mongoose G4 w/the same question you might get more info. there.
xrcbuggy is offline   Reply With Quote
Old 10-16-2005, 02:15 PM   #3
Rapid Roy's Avatar
You could also use lighter shock oil.
Rapid Roy is offline   Reply With Quote
Old 10-16-2005, 05:52 PM   #4
at the moment im using 50w in the front and 40w in the rear.What do you suggest i should change to ????
Old 10-17-2005, 02:51 PM   #5
Secret_weapon's Avatar
1- change shock position to lower.
2- decrease shock oil.
3- change the shock piston to higher number of holes.
4- use softer springs.
Secret_weapon is offline   Reply With Quote
Old 10-17-2005, 03:57 PM   #6
Rapid Roy's Avatar
Have you tried the harder tires with your current setup yet? You might discover that they give you about the same grip.
Old 10-17-2005, 06:25 PM   #7
quietstorm76's Avatar
Just put 40's all around and see how it runs. I wouldn't change anything right now. It should feel close to the old tires. What's the setup? Springs and camber?
quietstorm76 is offline   Reply With Quote
Old 10-30-2005, 10:06 PM   #8
Does anybody know of any websites that I could go to get pointers on what camber, caster, toe, roll center, etc. does to the handling of the car.
pelico is offline   Reply With Quote
Old 10-30-2005, 10:23 PM   #9
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I set the the car up to run 35 fronts and 37-40 rears!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-31-2005, 02:07 PM   #10
Thanks SlotMachine, but was referring to what effect the camber, caster, toe, etc. has on the handling of the vehicle when each is changed.
Old 10-31-2005, 02:12 PM   #11
Data's Avatar
try this
Data is offline   Reply With Quote
Old 10-31-2005, 02:36 PM   #12
flack's Avatar
Default Setup Book
I bought the XXX Main setup book. I think it was well worth the money.
http://www.xxxmain.com/bookz.shtml
It not only explains what the adjustments are and how they work but what order to use them.
Doug
flack is offline   Reply With Quote
Old 10-31-2005, 02:50 PM   #13
Thanks Data....I will begin my studying as soon as possible .
HELP!!! ESC Issue Chris__RC Electric Off-Road 6 08-31-2008 01:31 PM
XXX-S Issue Sweeney921 Electric On-Road 18 01-22-2007 08:07 AM
DPD issue Racingfreak6 Electric On-Road 5 01-01-2007 09:56 AM
OS .12 5p issue Black_Widow Nitro On-Road 4 12-18-2006 10:19 AM
tuning issue bt Nitro On-Road 15 05-06-2003 03:40 AM
