Old 10-15-2005, 09:43 PM   #1
Default Stuck Sleeve
Hey everyone!! I have this engine wherein the sleeve is jammed in. A simple tie strap wont bring it out and I've tried pushing it out from the backplate opening. I've tried some other stuff like putting it over the stove and then I tried goin the other way by sticking it in the freezer but I may have done it wrong. So maybe you guys have a different approach to this? Id appreciate any ideas. thanks!
Genius is offline   Reply With Quote
Old 10-15-2005, 09:52 PM   #2
EdwardN's Avatar
What motor is that? What is the reason sleeve got stock-conrod broken? or just want to take it out for maintenance? Does sleeve move a little bit or completely stack?
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 10-16-2005, 01:11 AM   #3
Actually its an old engine of a friend and im just trying to revive it. Its a MAX .12 or .15 on road engine. I think he said that he put a drop of dura lube or something (I have no idea why) haha. Nothings broken I just want clean up the inside. The sleeve wont seem to budge, no movement at all.
Old 10-16-2005, 06:48 AM   #4
EdwardN's Avatar
Attach fly wheel to engine and tigh it as normal. Heat up engine to 280-290 F and put 3 tie wraps ( sometimes one doesn't work) and try to turn over by fly wheel with channellock pliers. Should go.
Edward
Old 10-16-2005, 07:45 PM   #5
Trader Rating: 36 (100%+)
I had the same problem a while back. End of story, I destroyed the engine by trying to force it out with a small metal pic, lol...but I learned something that will likely work.I had tried the zip tie method to no avail. They are simply too soft. So, I tried (with a different engine) using a plastic shock spacer. Put it on top of the piston and drop it to BDC, then slide it half way off the piston, so it just barely grabs the bottom of the sleeve, then simply turn the flywheel as you would with the zip tie method. This should work due to the harder and thicker plastic that the spacer is made of.
NitroOB4You is offline   Reply With Quote
Old 10-17-2005, 05:56 AM   #6
cdelong's Avatar
put a flywheel on nice and tight....... soak the engine in WD40 overnight....heat the engine with a hairdryer.......use a LARGE ziptie
it will come out.
cdelong is offline   Reply With Quote
Old 10-17-2005, 09:09 AM   #7
Hey guys thanks for the great tips! I finally got that stuborn sleeve out. I soaked it with WD-40, found a thicker piece of plastic, and I heated it up. what a great feeling to finally get that thing out of there. thanks guys!
Old 10-17-2005, 10:05 AM   #8
jrabbito's Avatar
Just be careful with WD-40. I have seen people who have soaked an engined in it. If your engine is modified it can remove the silicone in the crank. Otherwise your safe.
John
jrabbito is offline   Reply With Quote
Stuck sleeve....help.......... Taylorm Onroad Nitro Engine Zone 7 12-03-2007 06:13 AM
sleeve stuck in engine plz help? downunder23 Electric Off-Road 5 08-24-2006 04:17 AM
Stuck sleeve....tricks??? NitroOB4You Onroad Nitro Engine Zone 3 08-23-2005 02:40 PM
Need Help with Stuck Sleeve!!! serpentsixty9 Onroad Nitro Engine Zone 10 07-25-2004 08:26 PM
Okay, Now I'm Stuck finny Australian Racing 8 04-18-2004 07:37 PM
