Old 10-14-2005, 04:34 PM   #1
Default Building Reciver packs
I am building a reciver pack and was just wondering if 4 x 1.2v 800mah batteries is enough for a 45min final?
Thanks in advance
Brett.w is offline   Reply With Quote
Old 10-14-2005, 08:56 PM   #2
Id say you just might be able to make it but the battery might be really weak in the end and you really have to be sure that you charged that battery properly. But once your batteries get older and more used up they will not last as long anymore. So to be on the safe side I would still go with a minimum of 1100mah batteries and use the smaller 800mah for qualifying. Keep in mind that 4 batteries will only equal 4.8 volts which is definitely not enough. Normally servos run on 6 volts.
Genius is offline   Reply With Quote
Old 10-14-2005, 09:18 PM   #3
rcabj's Avatar
i've got 2 sets off 800 & 900 mah self build AAA receiver battery.
but they r all in 5's per packs...and they r last me a few 45 min. mains so far...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 10-15-2005, 09:52 AM   #4
asw7576's Avatar
Thanks in advance
Yes, 800mah batts are enough to complete 45min final. My friends use 750mah for 1 hour final, but he re-peaked before final.
I thought Serpent 710 needs 5 cells ? Servos become lame with 4 cells.
Old 10-15-2005, 12:14 PM   #5
Seisick's Avatar
4 pack battery lasts longer but has less torque and speed on servos! not recommended, gp 900s aaa repeaked before one hour main should last without any problem for digital servos, except on situations where there´s a rain delay!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Building saddle packs? ryanroma Rookie Zone 6 08-28-2008 03:15 PM
help building battery packs benben10 Electric On-Road 8 07-13-2008 11:04 AM
Building Battery packs FALCON-LORD Rookie Zone 12 06-02-2005 02:28 PM
Building Cell Packs C3PO Electric On-Road 4 08-09-2004 07:58 AM
building battery packs azenis Australian Racing 5 07-09-2004 05:03 AM
