Old 10-12-2005, 10:35 AM   #1
Default Drag Brake
I've heard a lot of top driver using drag brake. I'm driving a Serpent 710 with front one way. what is the best way to set up the drag brake? Anyone who has experience with drag brake please share the pro and con of it. Thanks
alan is offline   Reply With Quote
Old 10-12-2005, 11:39 AM   #2
Rapid Roy's Avatar
Setting up drag braking is pretty simple. You turn on your radio and leave everything in the neutral position. Then you just tighten your brake adjustment thumbscrew until there is just a little bit of resistance when you roll the car. What this does is give just a touch of braking when you release the throttle. You can free roll if you barely keep the throttle cracked open. I used this setup most when I ran a one way on a permanent high bite track. Mid corner adjustments were easier because letting off the throttle mid turn would give you just a touch of brakes and allow the car to slow a bit without spinning out.
Rapid Roy is offline   Reply With Quote
Old 10-12-2005, 01:56 PM   #3
beware this will add more stress/wear on the brake and clutch. another method would be find a rubber band that counter pulls on your trigger that will give you the same effect and tunable on the fly.
dshy is offline   Reply With Quote
Old 10-12-2005, 06:14 PM   #4
Rapid Roy's Avatar
What!? A rubber band isn't going to do the job. You might as well tell him to press on the brake just a little bit so it acts like drag brake. If you want to adjust the amount of drag brake you can use the radio trim while you are racing. Also the pressure you exert on the servo is very small. With drag brakes you want a very small amount of braking. I effect you want is kinda like coasting up hill.
Old 10-13-2005, 09:18 AM   #5
ziggy12345's Avatar
I use the trim to increase the drag brake during racing. The more drag brake you run the more it will tun in off power. You will know when there is too much as the car will spin out off power.
If you have a 3PK then adjust the trim so it increases in 2% increments per click instead of the default 5% this will give you more control over the amount you add.
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-13-2005, 09:54 AM   #6
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I have a friend of mine tat uses drag brake, and after 3 minutes the brakes heat up and puts too much drag on the drive train. I would say don't use drag brake. Use the anti-lock feature that seems to be present in most modern radios. I think it will be more consistent once you have it set up right.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-13-2005, 10:11 AM   #7
Rapid Roy's Avatar
Your friend has too much drag brake if he is overheating the brakes. You only want to have a little. I like having just a little bit of drag brake because it gives me better response when I transition between throtle and brake. There isn't a dead zone at neutral trigger that way.
Old 10-13-2005, 11:38 AM   #8
Default Brakes
Set the initial drag on the car linkage and the max braking on the radio (endpoint)
Then it can be fine tuned during the race with the throttle/brake trim.
s8in is offline   Reply With Quote
Old 10-14-2005, 08:27 AM   #9
Thanks for all the comments guys. I'll try to set up drag brake in my 710 and see what is the result.
Old 10-27-2005, 09:49 PM   #10
texasRanger's Avatar
Thanks all for the "Drag Brake" setup, looking forward to trying it on my
V One S, it may just suit the way I drive (and my radio).
One question while the topic has been brought up, how does the "Anit-Lock" feature work on a modern radio ?
I currently just have a simple two channel basic radio, carried over from my years in RC Gliding, so I am not up with the latest computer radio's just yet.
Thanks inadvance
texasRanger is offline   Reply With Quote
Drag Brake Bandeira Nitro On-Road 8 07-31-2009 05:13 PM
3pk drag brake Nitro Herb Radio and Electronics 3 01-09-2008 07:00 PM
ECS- Auto brake/Neutral Brake/Drag brake RC12L3a Electric On-Road 6 11-21-2004 10:10 PM
drag brake, brake and reverse imjonah Rookie Zone 3 07-24-2004 07:20 PM
Drag brake Peter Busch Electric On-Road 7 06-26-2002 11:54 PM
