Mugen Seiki Racing's Nitro MGT7
#211
Hi All....
This race will be my first outing with the new car, my MGT7.
2015 Great Lakes Challenge - Toledo, Ohio, August 28-30th 2015
http://www.rctech.net/forum/nitro-ro...th-2015-a.html
Is anyone else taking their's to this race?
It should be another good one!!
Regards
BM
Regards
BM
#213
I've created an editable setup sheet and it can be downloaded here:
https://mega.co.nz/#!KYZCDCZa!qA3ON2...aAwU_Er9WsS5ZM
Please let me know if you find any errors and I'll update the file.
#214
Regards
BM
#215
Weight Distribution
The weight distribution on these cars is really good but does any one use a smaller battery then the 2200 and 2500mAh I use?
For instance. Does any one run like a 1450mAh battery in their car?
Regards
BM
Regards
BM
#216
I just installed a 1600mAH LiFe pack from trakpower. It fit like it was made for it!!!!
#218
#219
#220
#221
I'll be racing my GT7 for the first time this weekend and haven't been/won't be able to do much testing so I'm curious which setup most of you people are running.
Standard setup or Robbie Cerrato's?
What are the major differences in handling?
Do most people modify the upper arms to reduce caster?
#222
Robbie does say that he uses this as his base set up at the track he normally runs at which has quite high traction so I guess if your going to run your car on a track with less then high traction, you may need to alter the diff' oils?!
Myself, as the GLC is usually high traction I will start out with Robbies set up. The only difference being 550cSt oil in the shocks.
Regards
BM
PS: Also. Not sure if Robbie runs the outer steering tie rod under the front upright plate or not but that also improves steering/ reducing bump steer!
#224
