Old 10-09-2005, 01:20 PM   #1
Default Differnce between efra and ifmar engine?
Can anyone explain the difference between an efra legal and ifmar legal engine. I think it has something to do with the crackshaft hole.
Which one has more power or rpm? What the difference regarding power and rpm?
Can I use an sirio .12 evo 2 efra crackshaft in a sirio .12 evo 2 ifmar engine? If so, how should i retune the engine? leaning or richen the HSN?
hendrikcls is offline   Reply With Quote
Old 10-10-2005, 02:11 AM   #2
Dynamite's Avatar
Send a message via MSN to Dynamite
efra cranks are limitted to a 6mm crank hole, whereas ifmar crank afaik isnt limited at all.
yes you can use a evo2 efra crank in the ifmar evo2 motor if you wish, they all start life as the efra type then have a sleeve pushed into them to restrict them back apparently. as for retune, i'd probly say motor would need to be run a leaner to negate for the smaller crank hole.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 10-10-2005, 03:55 AM   #3
ziggy12345's Avatar
I think its 7mm isnt it? Also the hole from the crank must be unbroken by the turbo scoop
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-10-2005, 04:05 AM   #4
So do u just remove the sleeve to make it to the ifmar's version?
tiger266 is offline   Reply With Quote
Old 10-11-2005, 01:26 AM   #5
Dynamite's Avatar
Cheers
hey ziggy,
i measured the crank inlet of my mega zx12 motor when i first got it to check insides before running in and measured the crank inlet to be 6mm. So i just assumed, and i was sure someone else also told me a while back it was a max 6mm for efra crank hole, but i could be wrong.
you must be right about the crank hole not allowed to be unbroken by the scoop, as the little scoop if you'd call it that, that it does have is only really a little mark or slight swirl on the counter balance.
hendrikcls,
i dont think you will be able to get the sleeve out, most likely one metal was heated and the other cooled then slid in making impossible to seperate once united. your best bet would be to purchase a ifmar crank if your worried about it, you will get good performance by tuning your motor right with the efra crank then having an ifmar one and being off on tuning, this is just how i would feel about the situation.
Engine Max Power XL3 .12 with pipe max power efra 2602 dht R/C Items: For Sale/Trade 22 11-03-2008 12:57 AM
RB V12 R3 EFRA-IFMAR 2008 RC HulkNT1 Nitro On-Road 3 05-13-2008 06:58 PM
EFRA AGM 2007 kentech Electric On-Road 20 11-08-2007 12:38 AM
Difference between EFRA & IFMAR Spec Engines? pelico Onroad Nitro Engine Zone 9 08-31-2006 01:05 PM
any 1/8 efra racers here? -Nitrohead- Nitro On-Road 0 12-04-2003 06:44 AM
