Spektrum system mods >
Old 12-13-2005, 06:01 AM
  #46
Default Antenna
HI Guys:
Does any body knows, what kind of cable I can use to replace the antenna on my receiver, the cable snap at about 3 inches and I loose signal at about 40 feet.
Does any body knows if it is aluminum or cooper??
Edgar
Edgar Millenium is offline
Old 12-13-2005, 08:11 AM
  #47
stefan's Avatar
Originally Posted by Edgar Millenium
HI Guys:
Edgar
It's silver colored wire inside, but that shouldn't matter.
But whatever you do, DO NOT unsolder the antenna wire from the circuit board.
When you look at it, it looks as if the wire was going through the board and is just simply soldered to the underside of the board, but that's not true.
It's too complicated to explain, but the antenna actually connects to the upper side of the board and it's nearly impossiple with a normal iron to get that done right.
Been there, done that, got no shirt
So, just attach the missing length to what's left of your antenna.
IMHO, the antenna wire is crap. It's getting brittle quickly and then breaks. Mine broke directly at the circit board.
stefan is offline
Old 12-13-2005, 11:41 AM
  #48
Moderator
Uneke's Avatar
I successfully replaced the antenna on my rx last summer when it got pulled out. I have a pretty large tipped iron and i did it during my 3 min warm up beforemy heat race. I don't remember it being that much of a problem and I haven't had a problem with it ever since.
Uneke is offline
Old 12-13-2005, 01:07 PM
  #49
stefan's Avatar
Gimme your address, you'll get my next RX if I have an antenna problem..
I guess i'm just clumsy then
stefan is offline
Old 12-13-2005, 02:24 PM
  #50
Data's Avatar
any 30AWG hookup wire will do, make sure it is multi-strand bare copper (or tinned copper) conductor and PVC insulated.
Data is offline
Old 12-13-2005, 03:12 PM
  #51
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Just for informations sake , does the wire have to be a certain length like RF RX's or can you just get any old wire length and put it on. I know with RF RX's if it breaks you basically have to send into the company to have them professionally repair it otherwise you could have glitching as the length of the RX has something to do with the tuning frequency.
Artificial-I is offline
Old 12-14-2005, 09:27 AM
  #52
Data's Avatar
antenna length is a function of the frequency. for a 27MHz system, a good antenna length would be around 208 inches, but obviously it is not practical for RC, so I guess they use a fraction (properly 1/8) of it. it will loose some range i guess, but for RC, the reduced range is good enough anyways.
my RXs antenna is 4 inches shorter than when i got it, but so far i had no problem with it. either i am very lucky or a couple of inches does not really matter.
Data is offline
