Spektrum system mods >
Old 11-01-2005, 06:35 AM
  #31
ziggy12345's Avatar
Ok i'll go check mine
Thanks for the info. BTW i was half assleep and read it as the RX
Cheers
ziggy12345 is offline
Old 11-01-2005, 06:48 AM
  #32
ziggy12345's Avatar
Well I just opened mine up and its a black wire. I had enough room to rotate the connector 90 deg and move the wire away from the board so Maybe its OK.
I also saw there are 2 connectors on the board. can you use either of them?
Cheers
Old 11-01-2005, 02:32 PM
  #33
mine is a black lead but is really long and runs round outside of pcb!
Cartman is offline
Old 11-04-2005, 09:47 AM
  #34
New Service announcment from Spektrum
Check it out here
http://www.spektrumrc.com/DSM/Next/Default.html
erock1331 is offline
Old 11-04-2005, 11:10 AM
  #35
Arno's Avatar
Cheers
You have to use the one closest to the outside.
Arno is offline
Old 11-09-2005, 01:06 AM
  #36
Tzadkiel's Avatar
Default spektrum binding
Originally Posted by etgdpu
Hi all,
No, it is not like that. You bind the Rx with the Tx only the first time. What is happening is that the Tx downloads its unique id to the Rx. From then on the Rx "searches" only for the Tx with this id.
Whenever you power on Tx and Rx, they handshake at the channel 0 and they set up an appointment to the first free channel of the other 79 (total 80, 0 for handshake and 1-79 for actual usage). So, if you power on and there are other 3 active spektrums you will get the 4th channel, which is the first free. In the extreme case where there are another 79 active, yours will simply remain at the failsafe status, because it will be impossible for the Tx to connect with the Rx. Every time there is not contact between them, the built in Rx failsafe is activated.
I 've been using it for the last 5-6 months without any problem.
Regards
Actually it doesn't pick the next channel that way; it picks the channel with the lowest noise.
Tz
Tzadkiel is offline
Old 11-09-2005, 06:26 AM
  #37
etgdpu's Avatar
Maybe at a second level, it searches for the channel with the lowest noise, but at first it needs to exclude the already occupied channels. If you have more details on the channel selection algorithm, please share them with us.
etgdpu is offline
Old 11-09-2005, 02:40 PM
  #38
luketob's Avatar
guys, i bought spektrum system for m11 and ran the car yesterday. I experienced total shutdown 3 times...thought it was the battery, charged it and still doing the same thing, but i noticed that the shutdown only happened if my car was riding on the metal circle corners. I opened up the tx the wire is grey and very long, pretty long it goes around the circuit board...so i assume my tx is the update version...how you place the receiver could be the problem? maybe someone can help me or point out what the problem is...thanks guys!
luketob is offline
Old 11-09-2005, 10:31 PM
  #39
Tzadkiel's Avatar
Since it's a direct-sequence spread-spectrum form of modulation, there is effectively no difference between an occupied channel and a noisy channel. As far as the Spektrum is concerned, it's all noise. It doesn't matter if another channel is noisy because another Spektrum is using it, or it's noisy because some other 2.4GHz device is using it, or it's just plain noisy - it'll pass it over and look for a quieter one.
As an interesting aside, direct-sequence spread-spectrum is what our GPS satellites use.
Tz
Tzadkiel is offline
Old 11-10-2005, 11:30 AM
  #40
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
So the Capacitor is pretty much only for the 1/12 cars? I bought one in case I needed it. I shouldn't have to put it on the nitro car should I?
GrandeGixxer is offline
Old 11-10-2005, 12:11 PM
  #41
ziggy12345's Avatar
The capacitor will help when the battery gets low and stops the system kicking in the failsafe. I put one in my car and it seems to last a bit longer between charges
Cheers
Old 12-06-2005, 12:10 PM
  #42
Lou Decruss's Avatar
fcc has not approved this
http://www.rctech.net/forum/showthre...68#post1983168
Lou Decruss is offline
Old 12-06-2005, 01:13 PM
  #43
GundamWZero's Avatar
Originally Posted by Lou Decruss
Bakas...................
How can you say that its illegal and you don't even know for yourself? You are still confused from the EULA yourself, then you post a link to your OWN THREAD and it haven't been concluded wether that they are!!!!! What these guys are trying to stop glitching problems and you are still stuck on the notion that the system isn't legal, although its already been FCC approved BEFORE the first batch was ever shipped!!!
GundamWZero is offline
Old 12-06-2005, 09:56 PM
  #44
Registered User
OB42TC3's Avatar
Just thought I'd let it be known that I ran my Novak GTB/Spektrum/Helios/KO dig servo 1/12 4 cell car on carpet and had no issues or need for the capacitor..and it was rock solid, no glitches like last year in a high glitch environment.
OB42TC3 is offline
Old 12-12-2005, 09:57 PM
  #45
sixandeightstri's Avatar
Default modified - moved antenna to stock location
I had a bit more trouble moving the antenna to the stock location, thanks to the following:
  1. My 2-stick radio's stock antenna location is too far away to use the stock antenna/cable, especially since I have the 1st gen "black" short cable
  2. The dudes at Horizon absolutely refused to sell me an "updated" antenna with the longer cord, insisting that I'd have to send the whole module in for "service"
So I said, "screw you guys, I'll figure this out myself." After some digging, I determined that the connector for the antenna to the board is an IPEX panel mount connector, and found a pigtail connecting one of those to a new 2.4 ghz antenna (using a n-type connector). With a little ingenuity and an old plastic piece (and some super glue) I fashioned a mount where the old antenna was, and things seem to be peachy:
Attached Thumbnails Spektrum system mods-exzes1.jpg   Spektrum system mods-exzes2.jpg   Spektrum system mods-exzes3.jpg
sixandeightstri is offline
