Old 10-03-2005, 03:25 PM   #1
Default Gear Ratio
Hey guys, was wondering how I could get more top end speed using gear ratio. Do I go smaller on the spur gear and bigger on pinion gear or vice versa?
Thanks.
If there's another thread about this, please give link to same.
pelico is offline   Reply With Quote
Old 10-03-2005, 04:06 PM   #2
Bigger on the pinions smaller spurs makes more speed.
Van-Smack is offline   Reply With Quote
Old 10-04-2005, 01:41 PM   #3
Arno's Avatar
Arno is offline   Reply With Quote
Old 10-04-2005, 02:38 PM   #4
Thanks guys....I'll try it out the next time at the track.
Old 10-17-2005, 12:51 AM   #5
rs4 3 i just upgraded the clutch,flywheel, ported the header, can i upgrade the gears for even more top end speed im still new the to rc, you guys said go bigger on the pinions and smaller spurs, has any one tried doing this on a rs4 3 w/2speed tranny, maybe i can get some part #s or something,and will a ball differential set and a front one-way differential make it faster too. any info will help. thanks
hybrid_eg6 is offline   Reply With Quote
Old 10-17-2005, 11:04 PM   #6
anyone?
Old 10-18-2005, 12:05 AM   #7
Rapid Roy's Avatar
Changing the gearing as explained above will give you more top speed. The downside is you will loose some low end acceleration. By changing the gearing you can balance the acceleration and top end to your track or driving style. The ball diff and front one way are to increase handling, which will make you faster around a track. If you use the front one way, you will loose the front brakes. For a new racer, I would recomend using heavy diff oils. Heaver in the front then the rear. Make sure that you seal up the diffs first though.
Rapid Roy is offline   Reply With Quote
Gear Ratio maximuspowell Nitro Off-Road 4 08-22-2008 05:17 PM
pan car gear ratio joe of loath Electric On-Road 2 04-03-2008 10:13 AM
Gear Ratio ww racing Rookie Zone 3 06-22-2007 02:56 AM
Gear Ratio Secret_weapon Electric On-Road 0 01-05-2005 05:52 AM
