Old 07-16-2010, 11:45 AM   #76
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Default Serpent Impulse parts blowout!
Was at SpeedtechRC yesterday. They found an old box of nitro parts that had been stored away. Among them were a bunch of Serpent Impulse parts just about everthing for the car including a brand new chassis plate.
They won't be listing them on their website so you'll have to call them to find out if they have what you're looking for. Call them at: 626-237-0807
YR4Dude is offline   Reply With Quote
Old 07-20-2010, 01:03 PM   #77
stitchy's Avatar
This is what we got:
o-rings aluminum front axle 1065 1
Spec. clutch springs 6518 2
Brake plates 9602 3
Steel Brake Disks mk-2 9611 2
Brake Pads Black 9621 1
Pro gear 47T 1st 9647 3
Pro gear 48T 1st 9648 2
Pro gear 49T 1st 9649 1
Conversion set carbon radio plate 801110 0
Shocktower front carbon 801116 1
Shocktower rear carbon 801118 1
Impulse Chassis plate 2mm 801180 0
impulse steering block left 801210 2
impulse pro wheelaxle front 801214 1
wheelaxle front 801215 2
Ipu pro driveshaft front 801221 0
Front axle, one way bearing, 24T 801242 1
impulse pro wheelaxle rear 801314 1
impulse wheelaxle rear 801315 1
Ipu aluminum wheel adaptor rear 801317 1
Disk brake ventilated 801345 3
impulse rear differential 801371 2
impulse gear diff housing rear 46T 801375 2
impulse gear diff plan 801380 2
gear diff plan aluminum 801381 1
impulse gear diff axle rear 801385 2
impulse gear diff driveshaft adaptor 801388 2
impulse gear diff bushings 801390 1
impulse gear diff pins 801391 3
impulse pro gear diff adaptor 801393 2
Impulse gear 2-speed 47T 801417 2
Clutch shoe graphite m-12 801525 1
Flywheel sx-12 2sp 2p 801541 1
gear pinion 12T 1st 801542 4
gear pinion aluminum 15T 2-sp 2nd 801545 3
gear pinion aluminum 16T 2-sp 2nd 801546 2
gear pinion aluminum 17T 2-sp 2nd 801547 1
Bearing block front right 808202 0
Wishbone front top left 808203 1
Wishbone front bottom right 808206 1
Pivot pins front top 808210 1
Pivot pins front bottom 808212 1
Spacer Set Caster 808214 2
Pulley/flange 24T 808229 2
Pivot pins rear top 808315 1
Pivot pins rear bottom 808317 2
Pivot balls 8.5mm 808346 1
Bearing block rear left 808350 0
Wishbone rear top left 808356 2
Wishbone rear top right 808357 2
Wishbone rear lower left 808358 2
Wishbone rear lower right 808359 2
Solid axle pully 46T 808371 2
Shock absorber parts nylon f/r 909401 0
Spring set orange, d=1.4 909414 1
Centax pinion gear aluminum 16T 909556 2
Centax pinion gear aluminum 17T 909557 2
Centax pinion gear aluminum 18T 909558 3
Centax pinion gear aluminum 19T 909559 1
Centax pinion gear aluminum 20T 909560 1
gear 2-speed 44T 909644 2
Gear 2-speed 45T 909645 2
gear 2-speed 46T 909646 1
Speedtechhobbies.com
stitchy is offline   Reply With Quote
serpent impulse pro tony montana R/C Items: For Sale/Trade 4 12-25-2007 02:23 PM
Serpent Impulse RTR TheDon502 R/C Items: For Sale/Trade 4 11-15-2007 04:46 PM
Serpent Impulse F/S F/t xxxssportracer R/C Items: For Sale/Trade 0 05-05-2003 08:53 AM
***Serpent Impulse Hop-ups*** PUNISHER R/C Items: For Sale/Trade 1 04-10-2003 05:28 PM
