Os .18tz .. Mod?
#77
#78
A few questions illmatic94 what brand car are you running? What shore tires are you running on the back? What gear ratio are you running?? And how many turns in is your shift screw turned on your 2 speed??
#79
That video is a little out dated (a month ) right now I'm running it in an X-ray nt1 first gear ratio is 6.5 for 1st and 4.5 for 2nd roughly. Those are fdr.i was running 40 all around in te video I'm running 35 all around. And i believe the 2 speed is set good now.it was relatively loose in the video. (Shifting almost immediately
