Os .18tz .. Mod?
#61
Try this company for custom gears. http://www.sdp-si.com/ You can call them up too they are very helpful.
#62
#63
No I don't know everything!!
#65
............Is that pipe originally made for a .12 size motor?? I had a Vantage .18 size pipe on my OS.18 but it looks like they have gone outta business.
#68
#69
I believe that your tranny is skipping first gear and going immediately into second gear continue to adjust the shift point screw about 1/8 of a turn until hear it shift. Looks fast!!
#71
18tz is the way to go with a small block set up. Mines was done by Maxy from Maxy's Fuel and hit 90 at the 2009 ISC event. Similar set up to what NH has with the vantage pipe but was in an HPI Racer2. The car had been close to triple digits in testing.
#75
I think you must look at the 4-stroke conversion kits, there are larger pinions with it.
