Os .18tz .. Mod?
#46
One off a Nova Rossi .21 motor . But let a engine builder put it on the motor. You would have to bore out the carb opening on the TZ.18.
#47
Ok thanks man
#48
What manifolds are you guys using with 18tz and also carb restrictor
#53
.................When you start putting a big block in a 1/10 scale onroad car be ready to do some improvising, in other words making you own parts , for your X-RAY you may have to make your own engine blocks to make everything line up right.
#55
If not, try to get 3x5 shims you can place between the crankshaft and the endtip.
#57
Did you remove all the shims? If so when screwing the endtip and the clutchbell is locked up you should check the cone. If there is a lot of space between the engine front bearing and the fly wheel yoy should try another cone or grind down the current cone.
#58
Search on youtube to SALVEN CENTAX and you will get a nice video how to setup a clutch
With a 1/10 the gap must be 0.5 to 0.6mm and the endplay still about 0.1 to 0.2mm
And yes, if there is enough room to get the flywheel closer to the engine and you can not sat the gap large enough then grind the cone at the engine side. If you still can not the the right amount of gap you can make the crankshaft longer with a 3x5 shimm on top of the crankshaft.
#59
