OS MAX 15CV
OS MAX 15CV
Hello,
What is the best nitro Fuel % for my engine, OS MAX 15CV? Do you think better 15% or 20% or no problem use 25%?
Thanks,
Best Regards
Thanks,
Best Regards
i only ran 20% on the 5 runs i got out of it but it was used and beat to hell and conecting rod and piston both broke. 20% will be fine idk about 25% but it should be. if its the engine im thinking of isnt it rated for 20-30%
Hello,
I think the manual says at least 18% oil and nitro 10% to 20%.
The nitro % is easy to identify at the Fuel bottle, where to find the oil %?
Despite the manual, is it possible to use 25% without damage the engine? The Engine have more a less 10 years old, but I only made in MAX 15 tanks, I disassemble it and everything looks fine, put a lot of after run oil and assemble everything again.
This is the motor:
Best Regards
This is the motor:
Best Regards
