Shepherd Velox V8 "EC" 1/8th Car >
Like Tree6Likes
Old 10-11-2015, 01:48 PM
  #16
JamesHealey's Avatar
A fantastic base setup which has worked very well with our team within the UK, the only error on this setup sheet is the front eccentric hubs should be in the upper notch (axles down).
Just thought i'd share this with guys out there as we never experience very high grip in the UK, so this maybe much more useful than a setup found at Euros/Worlds level grip.
This setup was used to win the BRCA national at Wombwell circuit, a very technical track.
JamesHealey is offline
Old 10-12-2015, 09:10 PM
  #17
Michael_T's Avatar
Trader Rating: 52 (100%+)
Thanks James,
Curious to know how you run 0mm rear offset with Matrix rims....I find that I have to run atleast 0.3mm rear offset to stop the rim from rubbing against the top of the hub.
Also, have you had a chance to run the new reverse clutch? I have installed mine, but haven't had a chance to run it yet.
Also, is the brass engine mount on your setup a genuine Shepherd item? What is the part number?
Michael_T is offline
Old 11-22-2015, 07:44 AM
  #18
Default Sheppherd V8-EC now 2015 World Champion!
Congratulations to Simon Kurzbuch and Team Shepherd!
cyberjoeone is offline
Old 11-24-2015, 01:26 AM
  #19
Originally Posted by Michael_T View Post
Thanks James,
Hi Michael, if you're using the standard steel axles that come in the kit then it shouldn't be a problem, if you're running the new hard coated aluminium axles, 0.5mm off set on the rear.
Cheers,
James.
Old 11-24-2015, 01:27 AM
  #20
Thanks James,
No the brass engine mounts were made by a workshop here in the UK, you can get the same effect by putting weight under the rear of the fuel tank under the flex bracket.
Old 11-25-2015, 09:41 AM
  #21
Taylorm's Avatar
Originally Posted by 1/8 IC Fan View Post
So anyone running the V8 here in the US?
Ted Hammer and Bill McLean in Toledo.
Taylorm is offline
Old 11-28-2015, 06:49 PM
  #22
gesser26's Avatar
There are quite a few people using the V8.
ShepherdUSA in here in FL.
Feel to contact us for any information.
Greg Esser
gesser26 is offline
Old 02-04-2016, 02:08 PM
  #23
When looking at pics of the car, I see some look like they're using mugen shocks. Is that the case? Why?
JOE SI is offline
Old 02-04-2016, 07:09 PM
  #24
Michael_T's Avatar
It's just the Mugen White springs, it's not the complete shock.
Shepherd white springs are very close (the Mugen one's are slightly softer, and slightly shorter).
Old 02-13-2016, 07:54 AM
  #25
BigC2007's Avatar
Need some info, is there any upgrade parts for a Shepherd Velox V8 11 with Pro kit upgrade & flex radio tray kit ? I am thinking about getting this but just wanted to know if there are upgrade parts for this.
BigC2007 is offline
Old 02-13-2016, 12:10 PM
  #26
Trader Rating: 18 (100%+)
You can do the EC upgrade kit. Velox V8 "EC" Upgrade Kit 900023
sliptrick is offline
Old 02-13-2016, 12:27 PM
  #27
The Shepherd Blue rear and red fronts are closer to Mugen Whites.
The Shepherd white rear and blue fronts are close to Mugen Greys.
Old 02-13-2016, 03:38 PM
  #28
BigC2007's Avatar
Thanks for the info Slip.
BigC2007 is offline
Old 02-21-2016, 05:41 PM
  #29
Noticed it's a little bit of a pain to get the front tires on compared to the rears. Does a rim trimmer open the hole for the axle as well? What tool is used for the axle hole?
JOE SI is offline
Old 02-21-2016, 06:18 PM
  #30
BigC2007's Avatar
Where can I find some Shepherd Decals/stickers, getting ready to paint a body ?
BigC2007 is offline
