Old 09-20-2005, 04:31 AM   #1
Default Should i use foam tyres???
are foam tires as good as rubber tyres? do they wear out quicker or do they have more wear on them? do they give more grip?
do u have to true them all the time?
also can you tell me why they are more expensive?
thanks
myk505 is offline   Reply With Quote
Old 09-20-2005, 08:06 AM   #2
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Its not a straight cut answer if its better. They can be more grippy on certain conditions.
Will they wear faster.......sometimes yes or no , again depends on the conditions.
No you dont have to true them all the time if you dont have extreme camber.
I can find nitro foams for 9 dollars a pair. I cant find a rubber tire , rim and insert for less than that. Usually spending 20 dollars a pair for that.
Artificial-I is offline   Reply With Quote
Old 09-20-2005, 08:24 AM   #3
Sow&Steady's Avatar
Foam is better, if this was your general question.
Wear - depends on track and the shore you use but for the performance-to-wear ratio, probably as good as rubber.
Grip - foams definitely gives a lot more grip.
No.
thanks
They are generally cheaper to buy compared to rubber tyres.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 09-21-2005, 04:27 AM   #4
what is the shore, what shore is for what type of conditions?
can you suggest some brands and/or sites to get good foams!
Old 09-21-2005, 04:47 AM   #5
asw7576's Avatar
What shore depends on track's surface ( grip level ) and track's temperature.
Ask your friends who use sponge tires.
37 or 40 should be good to start.
Old 09-21-2005, 04:55 AM   #6
is the shore similar to the way they grade rubber tires? Does anyone know any good sites for foams??
Old 09-21-2005, 06:49 AM   #7
Foams hook up great, but they chunk out easy if you are hitting stuff.
Homer Allman is offline   Reply With Quote
Old 09-21-2005, 07:26 AM   #8
ntc3freak's Avatar
shore is the hardness level of the foam.the lesser the number,the softer the foam
ntc3freak is offline   Reply With Quote
Foam Tyres OZDC Australia For Sale/Trade 6 11-05-2008 09:51 PM
Best Foam tyres stevelc Nitro On-Road 41 08-30-2008 11:04 AM
GRP Foam Tyres dev Australia For Sale/Trade 0 08-14-2008 04:39 AM
1/10 Foam Tyres - Twister Tyres LogiK Australia For Sale/Trade 4 08-13-2008 05:25 PM
Foam tyres or rubber tyres at IFMAR? habicht Electric On-Road 1 06-16-2005 11:02 AM
