Old 10-02-2002, 08:07 PM   #1
Default Handling when turning right
I have recently bought a Colt 10 4wd and have set it up. I have been testing it at a track in canberra located in Kambah. When running the car, all left turning works very well at any place on the track, however when I attempt to turn right, the car just seems to spin out extremely easily. This occurs even when I reverse the direction that I am travelling. Can anyone help.
My thoughts are
1. Crappy stock rubber tyres
2. Oil from exhaust being blown onto rear left tyre
3. Weight biased to one side of the car.
Thanks in advance to any help
scottyb is offline   Reply With Quote
Old 10-02-2002, 08:14 PM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Handling when turning right
My thoughts are
1/. it should affect both side
2/. likely if you run your engine too rich
3/. likely.
you should also check for suspension blinding, ride high, chassis tweak.
Manticore is offline   Reply With Quote
Old 10-03-2002, 12:40 AM   #3
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Yes, you car sounds tweaked. Check the tyres, suspension etc etc. I've raced a few times at Kambah, that right hand sweeper off the straight is hard to master, is it just that turn or all right hand turns??
Michael_T is offline   Reply With Quote
Old 10-03-2002, 01:44 PM   #4
hey dude,
Check all your ball bearings that fit on the cvds or axles.....If one bearing is seized your car will not handle properly.....
sKiMpYbOy is offline   Reply With Quote
Turning Radius bds Nitro Off-Road 7 06-23-2008 10:43 PM
jammin' jpx .28 not turning over???????!!!!! playboy Nitro Off-Road 3 05-08-2008 10:14 PM
Car turning right deceiver Nitro On-Road 6 03-21-2007 01:10 PM
Turning an Engine Over mrlacrosseman Nitro On-Road 3 09-26-2004 02:50 AM
Turning Hyper 7 Rtr To Pro??? famous182 Electric Off-Road 1 10-01-2003 09:28 AM
