Old 01-20-2003, 06:23 PM   #226
popsracer's Avatar
Default STS .12 Turbo Head Button for trade.
Anyone what to trade a STS Turbo Head button for a Standard plug Head button?
PM or E-mail if interested.
Thanks,
popsracer is offline   Reply With Quote
Old 01-21-2003, 10:14 PM   #227
InitialD's Avatar
Default Choice
Given the chance that both are priced the same, which one would you choose?
STS RS-5 Outlaw (5 port) or the STS RS3 (Modified 3 port)?
Old 01-21-2003, 10:19 PM   #228
DCR1TWO's Avatar
Default Re: Choice
I haven't tried the 5 Port, but the RS3 looks pretty good so far. I'm still breaking it in and it seems pretty responsive to needle adjustments. Still not as fast as my old MT12, but I'm still breaking it in. If you can get away with running a 5 port (local track rules), for the same price why not?
DCR1TWO is offline   Reply With Quote
Old 01-21-2003, 10:31 PM   #229
i just broke in my rs3 yesterday. I still need to do some tuning before i see the true power from my engine. also got to tune my centax to a better setting. seems like stock setting for my centax is a bit late.
rccraze is offline   Reply With Quote
Old 01-21-2003, 11:22 PM   #230
InitialD's Avatar
Default Re: Re: Choice
Yeah, there are no track rules to follow. Just wanted to know if the added extra mods on the RS3 has any significant advantage over the RS5...
Old 01-25-2003, 03:20 PM   #231
check out this forum also.
tweakster is offline   Reply With Quote
Old 02-15-2003, 10:09 AM   #232
Wolf's Avatar
Send a message via ICQ to Wolf
Default RS5
Hi,
I just got a STS RS-5, it deliver pretty good performance on track. However, my carb seems to have fuel leaking problem. After close inspection, the leaking seem to be comming from the gap between the foam filter and carb inlet (the lower part of the foam is a little bit wet). Do you have any comment or suggestion on this? It is by no means on the rich side on both the main and low end needle. The engine run fine in the trak with good low to high end speed and acceleration. (compariable with common 5-port engine)
I also notice fuel leak out from the glow plug while using a short #5 turbo plug nomatter how tight I screw it in. Looking at the top, it is very funny, just like boiling water bubble comming out at the glow plug and button interface! Any suggestion?
Wolf is offline   Reply With Quote
Old 02-16-2003, 12:25 PM   #233
Tech Chat Moderator
TheRagunCajun's Avatar
Well, sounds kinda fishy, but if knowone can help, email them about your problem. They are quick to respond and they are nice about it. So email them stateing your syptoms in a kind way. Check out this for the email info. http://www.teamcrc.com/CRC%20Contacts.htm
Wow these forums have gotten popular since 02!
TheRagunCajun is offline   Reply With Quote
Old 02-16-2003, 08:54 PM   #234
Wolf's Avatar
Thanks, I've post this under their forum about nitro engine. I think it is better to ask it open so that others can get access to the knowledge base and save their time and effort to answer the same question a thousand times. But it seems that they are very busy at the moment to help finding out the solutions.
Maybe changing the STS plastic carb with a Nova one may solve the leak problem but need to try it next time on track.
Old 02-16-2003, 09:18 PM   #235
omg my rs3 engine is so fast now. response is so quick and using a centax, one way and solid rear now. cant wait to test it on track. this engine is like the best one i tried to so far for the money. i also made a mod to the carb and i did see a little more performance in that. when i have the time im gonna tear the engine apart and do a polish on the crankshaft. try to squeeze every bit of power i can without having to run it lean or do major mods to the engine.
Old 02-16-2003, 10:54 PM   #236
skillas's Avatar
Send a message via ICQ to skillas
u guys know the needle setting for the STS RS5 turbo engine?.....
cause i just run in my engine ... and just want to know the needle setting for both top and low end needle for best performance......
STS RS3 setting would be good.......
skillas is offline   Reply With Quote
Old 02-17-2003, 01:23 AM   #237
Ron C.'s Avatar
Skillas,
There is no definite needle setting that anyone can give for your motor or any motor for that matter. This is because each one is defferent from another..
How about if you run the motor and let us know what it is doing. That is when people can probably help with suggestions:
I.e - too much smoke, bogging down, no power, over heating, no smoke, etc etc.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 02-17-2003, 01:40 AM   #238
skillas's Avatar
i gonna go down my local track and try to see wat happen then i will let u know........
Old 03-26-2003, 11:14 PM   #239
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default gas milage
Hey All i was wonfering how the gas milage is on a mod engine like the RS3 when compared to a non mod engie....
THanks Jason
jscamry is offline   Reply With Quote
M.speed modified nova RS12 Team-RTR Onroad Nitro Engine Zone 1 03-09-2005 09:47 PM
Mugen MTX 3 w/JP Modified RS12 MugenMTX3Kid R/C Items: For Sale/Trade 32 05-02-2004 10:48 AM
RB X12 1 Piece Pipe w/ JP Modified RS12? DOMOisCOOL Onroad Nitro Engine Zone 0 04-15-2004 06:28 AM
Novarossi rs12 s1 turbo aznxlionhrt Nitro On-Road 9 09-10-2003 05:43 PM
Novarossi RS12 Turbo .12 Tag R/C Items: For Sale/Trade 2 08-02-2003 08:48 AM
