Old 11-25-2002, 02:09 PM   #151
Send a message via AIM to ProRacer03
Hey guys, I recently ordered the STS RS.12 Modified motor. I was wondering if I would need to do anything to it in order to make it fit my NTC3.
It seems as though I need to do some sort of maintainence before I even put it in. It would be nice to get a definitive answer. Thanks! I got it because of this thread so smitty your plug worked.
I just want to make sure I got a good engine! And it wasn't $125 it was $149.99
The STS MT 12 was $125
what's the difference? between STS MT 12 and a regular MT 12?
ProRacer03 is offline   Reply With Quote
Old 11-25-2002, 02:53 PM   #152
the look
tagi is offline   Reply With Quote
Old 11-25-2002, 03:06 PM   #153
asd
Send a message via ICQ to asd
do not use toilet paper!!!!!!!!! it contains lots of dust, try to use a lint free cloth
also, just use fuel to clean the inside
asd is offline   Reply With Quote
Old 11-25-2002, 03:18 PM   #154
For cleaning the parts, I like to use a soft tooth brush in a cup of fuel. Just enough to submerge the parts, and get them nice and clean. You can dry them off with low compressed air, DO NOT OVER SPIN THE BEARINGS if you use air, you will ruin them quickly, remember you just cleaned any lube that was in there.
Proracer, I hope you enjoy it! I know I like mine
Smitty
smitty is offline   Reply With Quote
Old 11-25-2002, 04:25 PM   #155
theRED5's Avatar
R/C Tech Charter Subscriber
No, you shouldn't need anything to get it in.
RTD...that's "Read The Directions" , in the paperwork that comes with the engine it tells you to open the engine up and "rinse"it out completly, wiping off anything that may be inside...
I bought mine from a guy who's a "dealer", he has no overhead and just charged me Cost, so you could say the $24.99 was your dealers profit...
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 11-25-2002, 05:44 PM   #156
Send a message via Yahoo to TambokGT
Originally posted by smitty
I assume this stuff is for rust control, and it is always a possability to have machining flakes inside the engine, even your best makers have this problem.
Smitty
Very true......I see it in my Novarossi R1 and JP .21 engines. That would be the first thing I would do open the engine, clean it, and lube it, then break it in.
TambokGT is offline   Reply With Quote
Old 11-26-2002, 08:15 AM   #157
Nitro Tech
dino.tw's Avatar
Smile Thanks
Thank you,all brothers.I'm a little busy now.Thank you for answering those questions form me.I have to work harder now.The .21 is testing.....
dino.tw is offline   Reply With Quote
Old 11-26-2002, 08:57 AM   #158
Trader Rating: 16 (100%+)
I think that is a WRONG IDEA for STS to use MT-12 on their engine.........STS MT-12 is for Buggy use, not on-road engine at all, compare to the Mugen Seiki MT-12 engine......
Mugen Seiki MT-12 is for on-road, and that is NOT the same as the STS MT-12.....
See here...
http://www.teamcrc.com/inventory2003/stsmt12.htm
For on-road use, the RS-12 is the engine that we are talking about.....again, same as Nova Rossi RS-12 (I meant the name)
http://www.teamcrc.com/inventory2003/stsrs12.htm
Old 11-26-2002, 10:04 AM   #159
patelladragger's Avatar
Send a message via AIM to patelladragger
The MT-12 is an awesome engine on-road or off-road.
patelladragger is offline   Reply With Quote
Old 11-26-2002, 03:11 PM   #160
Here we go again !
Novarossi has tricked us by using the same name twice !
Mt-12 is the Mugen Novarossi onroad engine ( came with MTX-2 )
but Novarossi also have their own Mt-12 Novarossi offroad engine !
So you are both right
muugen is offline   Reply With Quote
Old 11-27-2002, 08:00 AM   #161
InitialD's Avatar
IF the shim is to large( meaning to big around) it will distort, and damage the deal. Trust me, I had this very problem, and Dino was kind enough to show me the light!
Smitty
Serpent at Mytsn just recently addressed this issue and posted a tip. I think it's the same problem with every engine when the shim is not placed correctly...
http://www.mytsn.com/publ/publ.asp?pid=6832
Old 11-27-2002, 04:49 PM   #162
I just got the motor from ups. Hey how do I know if it's a turbo or not? The box says turbo but I ordered a non-turbo I think..
I'll be cleaning the internals before I break it in!
Any helpful hints while I get this bootch ready?
It's the Modified RS .12 - What modifications were made to it?
Old 11-27-2002, 07:58 PM   #163
IF it is a turbo, then the plug hole will have a taper to it, that is the sealing part for the plug. If not, the the sealing area will be flat. I also got the turbo instead of the standard unit. In my opinion, you really should use the right head. I used a MT-12 button, and it worked, but when I installed the correct button, it seemed to run better. Give CRC a call, and see if they can help you with the button.
Smitty
Old 11-28-2002, 07:09 PM   #164
Default sts hand mod engines
well, this thread can definately be turned into an advertising gimmick for crc (and sts of course). Although I know the fact is alot of Taiwanese racers use STS engines but . . question is . .
is this little sts mod engine really as fast as JP ? Someone mentioned JP !! JP Black !!
and to say that taiwanese are good copy cats. .. copy cd, copy dvd, copy this and copy that and now copy JP ?? serious ?
Internal parts and mod cuttings are "the same" as JP ?
Are you sure ?
ed
racerchan is offline   Reply With Quote
Old 11-28-2002, 07:22 PM   #165
T-shirt's Avatar
Default Re: sts hand mod engines
Are you sure ?
ed
i agree with you chan.....
T-shirt is offline   Reply With Quote
M.speed modified nova RS12 Team-RTR Onroad Nitro Engine Zone 1 03-09-2005 09:47 PM
Mugen MTX 3 w/JP Modified RS12 MugenMTX3Kid R/C Items: For Sale/Trade 32 05-02-2004 10:48 AM
RB X12 1 Piece Pipe w/ JP Modified RS12? DOMOisCOOL Onroad Nitro Engine Zone 0 04-15-2004 06:28 AM
Novarossi rs12 s1 turbo aznxlionhrt Nitro On-Road 9 09-10-2003 05:43 PM
Novarossi RS12 Turbo .12 Tag R/C Items: For Sale/Trade 2 08-02-2003 08:48 AM
