Capricorn LAB C03 1/10th scale 200mm chassis >
Like Tree19Likes
Old 04-16-2019, 12:34 PM
  #286
chromie's Avatar
Can anyone help me with a starting setup for a med-high bite bumpy track? I would rather use 5 shore tire split and I only have available stock standard shocks (3hole/red springs)
chromie is offline
Old 04-16-2019, 02:04 PM
  #287
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
I was gonna post one, but in the process of looking for the editable setup sheet, i found this one i saved.
ToysRUsKid is offline
Old 04-16-2019, 03:07 PM
  #288
chromie's Avatar
Thanks! .. but is this track bumpy? downstop values look a little high
chromie is offline
Old 04-16-2019, 03:11 PM
  #289
dj apolaro's Avatar
Changes from that set up are.
Droop in front 0, rear 4
1Mil front diff
800wt shock oil
199 front width
35 front tire with 40 rear
rear roll center all the way down
stock front and rear sway bars
Everything else the same.
Try this and let me know if it works or you need more help.
Good luck,
DJ Apolaro
ToysRUsKid likes this.
dj apolaro is offline
Old 04-16-2019, 05:57 PM
  #290
chromie's Avatar
1Mil front diff
800wt shock oil
199 front width
Good luck,
DJ Apolaro
Thanks! will try and let you know
chromie is offline
Old 05-07-2019, 10:09 PM
  #291
I know I read somewhere that the total C03 clutch weight was around 30.5 grams, but I am curious about the weight of the other drivetrain parts, like the diffs, belts, and the two speed assembly...What did you guys find ???
bertrandsv87 is offline
Old 05-08-2019, 10:02 PM
  #292
Bundy_Bear's Avatar
They are all adequate... Capricorn has always been on the edge for performance with the racer in mind. Interesting the latest batch of C03 Evo kits now come with steel gears inside the diffs front and rear the same as Infinity and moving away from the lightweight graphite gears.
Bundy_Bear is offline
Old 05-08-2019, 10:06 PM
  #293
Maybe the composite stuff cost them a few podium finishes...
Old 07-03-2019, 09:34 PM
  #294
picco007's Avatar
Trader Rating: 97 (100%+)
Anyone who went to the KO Grand Prix this past weekend have a set up for the C03? We are thinking about making the trip for the Toys for Tots racing in December. Any help would be greatly appreciated!
picco007 is offline
Old 07-03-2019, 10:02 PM
  #295
ToysRUsKid's Avatar
I can send it to you before that race but i am planning to be there in december also.
Old 11-14-2019, 11:35 AM
  #296
British Menace's Avatar
Could I ask here. The pitch on the gears for the CO2 and 3 the same? Is it 0.8?
Regards
BM
British Menace is offline
Old 11-15-2019, 09:48 PM
  #297
Regards
BM
It's same
beebone is offline
Old 11-18-2019, 06:43 AM
  #298
Thought so..... thank you
Old 06-17-2020, 06:17 PM
  #299
F
illmatic94 is offline
Old 06-30-2020, 12:49 AM
  #300
Hi, Does anyone know CAP-16067K-V3 rear diff and Cap-16080K Front diff comes with internal metal gears or plastic? Thank you
Overland is offline
