Capricorn LAB C03 1/10th scale 200mm chassis >
Like Tree18Likes
Old 02-20-2018, 10:27 AM
  #271
dj apolaro's Avatar
The first part number is for the V3 latest shocks and the second part number is for when the shocks used clips to secure the piston.
They outer diameter will work in any big bore, however the piston is specific to the shock shaft. The new shaft takes a screw and the inner diameter of the newer version piston is larger for that part.
Hoe this helps,
DJ Apolaro
dj apolaro is offline
Old 02-20-2018, 11:10 AM
  #272
British Menace's Avatar
Hoe this helps,
DJ Apolaro
Thank you DJ.
Just what I needed to know.
Next time your on DJ. Can you tell me. Do you still use 1 hole, 500cst (50 weight) oil on your usual set up, even on the V3 Big Bore shock's?
Regards
BM
British Menace is offline
Old 02-20-2018, 01:33 PM
  #273
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Anthony,, If you went to the WinterNats, DJ prolly woulda built your shocks for you!!
TeamCarnage is offline
Old 02-20-2018, 04:58 PM
  #274
dj apolaro's Avatar
Originally Posted by British Menace View Post
Thank you DJ.
Regards
BM
So when I got my last kit I started using the standard shocks. It seemed the customers mostly ran the standard stuff and I wanted to show that either shock package can do well and also so I could help them more with the standard shock settings.
When I stopped using the Big Bore stuff I was typically using 3 hole all around or 2 hole front and 3 hole rear. Most of the time I used 1,000 wt oil with these settings and 3.9 springs front and rear. For super high traction I would go heavier with the oil and soft springs. 1300 oil and 3.2 springs or electric springs.
DJ
Old 02-20-2018, 04:59 PM
  #275
dj apolaro's Avatar
...you know I would have......
DJ
Old 02-20-2018, 10:01 PM
  #276
Trader Rating: 22 (100%+)
Will the C03 front lower bulkheads work on the C02? doing a rebuild on my car and one of my bulkheads has snapped at the rear and of course rctarget is out of stock.
noproblems209 is offline
Old 02-21-2018, 05:33 AM
  #277
dj apolaro's Avatar
Originally Posted by noproblems209 View Post
Will the C03 front bulkheads work on the C02? doing a rebuild on my car and one of my bulkheads has snapped at the rear and of course rctarget is out of stock.
I have never tried this, so I do not know. But I would not think so.
DJ
Old 02-21-2018, 11:50 AM
  #278
DJ
Thank you DJ. I appreciate the answer and the tip.
I will try the 3 hole all round and go from there.
I guess then, on Nick's advice. I'll bring all 6 pair's of Big Bore and 3 pair's of standard shock's for DJ to build for me next time hehe.
Should keep you busy for a little while DJ. Even at the speed you build this stuff
Thank's again.
Regards
BM
Old 02-22-2018, 05:47 PM
  #279
Anyone have a C02 right front lower bulkhead? have been looking around for one but no luck and of course I have a spare left side in my spares box
Old 02-24-2018, 10:46 AM
  #280
DS Motorsport's Avatar
It's possible to use C03 front lower bulkheads. You only have to grind away the small locating tab which is used for the eccentric bearing holders.
The C03 bulkheads have been strengthened to stop them from breaking on the known weak spot.
I have a complete used C02 front end available if you're interested. The left lower has a crack on the known weak spot.
DS Motorsport is offline
Old 02-25-2018, 10:05 PM
  #281
Thanks for the info DS! was hoping that was the case with the front bulkheads. Have plenty of Front end parts to last through the season just short on lower bulkheads.
Old 02-26-2018, 08:36 AM
  #282
Suspended
Trader Rating: 26 (96%+)
Default WTB C03
Im looking for a very low mileage C03. PM me if you have one for sale.
sbsprint is offline
Old 09-09-2018, 04:34 PM
  #283
chromie's Avatar
What spektrum receiver do you guys use in the receiver box?
chromie is offline
Old 11-03-2018, 03:16 AM
  #284
Bundy_Bear's Avatar
What do people use for the 5th body post on the radio tray of the C03? Do you use 15011?
Bundy_Bear is offline
Old 01-25-2019, 12:33 PM
  #285
dj apolaro's Avatar
Hi Guys,
I am selling one of my sedans. It is in great shape and I just rebuilt it like new. It has one of my motors in it and some KO low profile servos. Here is a link to the post and let me know if you have any questions. You can text me with questions 305-586-6072
Capricorn C03 EVO ready to go!!
Thanks,
DJ Apolaro
