Old 08-28-2014, 06:08 AM   #1
BRT
Default New prototype of "machine" to measure springs and diffs
Today I want to show you one machine a friend has design, which allow to measure and compare assembled differentials (to know which one will give us more traction or more control,...)
It allow to measure diffs mounted on the car, which gives a big advantage in any race.
Here you have the complete articles and videos (in spanish) but I think with a translator is easy to understand, and if you need more info you can ask here
Complete articles with videos:
Diffs:
http://www.cochesrc.com/medir-dureza...eva-a5818.html
Springs:
http://www.cochesrc.com/medir-y-comp...-rc-a5817.html
Thanks and hope you enjoy!!!! Please comment ideas, suggest improvements,... This is only a prototype.
BRT is offline   Reply With Quote
Old 08-29-2014, 01:42 AM   #2
BRT
Here the direct link to the videos:
+ YouTube Video
+ YouTube Video
+ YouTube Video
Old 08-29-2014, 07:07 AM   #3
tonylunatic's Avatar
Trader Rating: 45 (100%+)
That is really COOL!
Will definitely be a very useful tool. Any idea when a production type will be available. Or plans available to build one?
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is offline   Reply With Quote
Old 09-01-2014, 05:02 AM   #4
BRT
There are three prototypes at the moment that are being tested by some 1st level drivers.
After these tests which began in the past Euro Championship 2014, with good results, it probably goes into production,
Thanks!
Old 11-14-2015, 10:44 AM   #5
RoketRdr's Avatar
Did these ever make it into production? This is a very valuable tool that us racers could use.
TeamC GT8 - REDS R5 - Buku Clutch - RCShox
RC8.2 - Nova +21-4BTT - Buku Clutch
RC8.2e - Tekin T8 Gen 2 1900 w/ RX8 Gen 2 - RCShox
Highly modded Revo
Airtronics MT-4 w/ Radiopost servo's
RoketRdr is offline   Reply With Quote
Old 12-04-2015, 05:03 AM   #6
British Menace's Avatar
Yes. I would also be interested in knowing if anything came of this........
Regards
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 12-04-2015, 07:50 AM   #7
lil-bump's Avatar
Trader Rating: 83 (100%+)
I see no viable need for this machine. Why do I need to measure my diff action???
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-22-2015, 04:54 AM   #8
Pass you soon...
I like this idea myself.
Being able to test the resistance in your diff', the "diff' action" would, I think, be very beneficial for recording car set up's.
Being able to assign a number relative to the feel of a diff' would help in being able to replicate that same car set up in future.
I am sure a lot of driver's understand the importance of diff' setting's in racing, this machine would help in recording setting's that prove, on the track, to be ideal.
Going back to a track, pulling out your set-up sheet and being able to set your diff' to this "ideal" number will give you a real good start to your weekend's racing.
The shock spring tester need's to be handled a little more carefully I feel.
But it would serve the same purpose in set up as the diff' discussion above and would really work in the same way as colour coding of spring's we already have and use now. But applying a number to them. This number would relate to how strong the spring is and could be used in set up programs too.
In all. I like this machine idea.
Regards
BM
Old 12-22-2015, 07:24 AM   #9
lil-bump's Avatar
Regards
BM
I guess my true point is If 100k diff fluid worked well in the rear at a certain track that is all I need to know. I do not need to know what the resistance is for 100K. Can you tune 100K fluid for 110k??? I can not...
Matching springs is not in my race strategy. I just use the manufacturer data on the package for a reference. ie... If Xray says a spring is 30lbs then I go with that.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-22-2015, 09:18 AM   #10
delete
# Team Shepherd # http://rccar24.com/ # Brilliant RC # PICCO # Matrix Racing Tires # Hitec/Multiplex # looxon stickers
thilo-alexander is offline   Reply With Quote
Old 12-22-2015, 09:18 AM   #11
Pass you soon...
100k with Steel Gears is different to 100k with Carbon Gears, would be nice to know that "difference"
Old 12-22-2015, 11:38 AM   #12
Pass you soon...
I can understand that very much. I would say for some, it's a different way of keeping set up notes on your car.
One thing on diff's and tuning with silicone oil. Your 100K diff' may well have the resistance of 90K diff; the next time you fill it.... why?
Well, just for example, the first time your diff' may have been new with new gearing, new shims and o rings. The next time, all these will be broken in offering less resistance. You may not fill with exactly the same amount of fluid.
Also, the temperature your diff' run's in and get's to (ie A 1 hour final) will effect the diff' resistance.
Your 100K Diff will feel like 70K (With everything else being the same) in a one hour final in 95 degree heat!!
Knowing the resistance of your diff' via a number, you would be able to account for these irregularities.
It is a personal choice of course and I can well understand either approach.
My self, being a technical type, I would like the measuring machine.
Just on a side note. If a air pocket is left in the diff' when filling, this will cause more resistance, not in the diffing action, but in rolling resistance then if the diff' has no air pocket at all.
Regards
BM
Old 12-22-2015, 11:39 AM   #13
Good point.
Regards
BM
Old 12-23-2015, 10:08 AM   #14
RoketRdr's Avatar
Pass you soon...
You assume that you're diffs build the same way every time for a given fluid weight. They don't. Factors such as whether you use shims, gaskets, how tight you tighten down the screws, old vs new gears, how much run time is on the fluid, brand of fluid and how hot/cold the diff plastic is all determine how the diff is going to react and how much "tension" it creates. RC car diffs are not precision manufactured components and are quite sloppy. The fact that we are tuning with fluid weight in a plastic component is an indicator of how sloppy the accuracy and precision is. You can build 10 diffs on your bench the exact same way with the same oil weight/brand and I assure you the output tension will be different on each. For offroad cars this wont be as big an issue but still something has will have an affect on how the car drives and needs to be tuned. With us onroad racers it is far more critical to have consistency in the resistance of our diffs to be able to consistently and accurately tune our cars. And the spring rates are not the same between springs either. This tool would be extremely valuable.
Highly modded Revo
Old 12-23-2015, 11:35 AM   #15
lil-bump's Avatar
My point exactly...You just listed a ton of variables that could effect the resistance of a diff of which 90% of them you have no control over.
Where would your baseline be? There is no practical way you can tune a diff(other than changing the fluid) So why measure it... Maybe on a ball diff???
I am not trying to be a kill joy.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
