Old 09-03-2005, 09:48 AM   #1
Dragon's Avatar
Send a message via ICQ to Dragon
Default Rubber Tyres for Nitro
Anyone using Rubber for Nitro Cars?
Was thinking of trying Sorex 20R or 24R.... any suggestions?
the track i frequent has a rather oily surface, prob due to years of nitro...
Dragon is offline   Reply With Quote
Old 09-03-2005, 11:11 AM   #2
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I ran the take off pre mounted 32`s, they were pretty good.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 09-03-2005, 01:24 PM   #3
Roger's Avatar
Sorex 20'a and 24's will heat up too fast and you'll lose traction. Try any tire that is 32 and above. Try CS-32's or CS-37's. If you can find them, try some pit shimizu 36's with xenon gray inserts. They are dialed for nitro sedan. Goodluck.
Roger is offline   Reply With Quote
Old 09-03-2005, 03:56 PM   #4
heavy's Avatar
Trader Rating: 20 (100%+)
We run rubbers on Nitro all teh time mainly because the main track I race at is a concrete surface and foams don't work on that to well. We are now using rubbers at the tarmac track as well. Most common tyre chosen is the Sorex 36 and I personally use their B medium insert - works well.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 09-03-2005, 07:11 PM   #5
moot's Avatar
i'm using cs-27's on pretty slippery concrete. they work pretty well
moot is offline   Reply With Quote
Old 09-03-2005, 08:54 PM   #6
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Just be sure to use lots of traction compound. I basically sit my tires in a zip lock bag overnight before a race in after-run oil or tire tweak. This helps the tires become super plyable and sticky. Then apply some traction compound for ultimate stick.
Artificial-I is offline   Reply With Quote
Old 09-03-2005, 09:10 PM   #7
Dragon's Avatar
but will rubber work on oily surfaces?
So am i right by saying the lower numbers 20-28, have higher initial traction, but lose traction faster when they heat up, while higher ones like 30-26 have lower initial traction, but wont lose much traction when they heat up?
Old 09-04-2005, 12:16 AM   #8
Roger's Avatar
They sure will. Just apply some paragon on front and rear tyres and you'll be dialed. I practiced on a fairly oily surface that alot of nitro sedans raced on and my MTX-3 was on rails
Old 09-04-2005, 01:17 AM   #9
Dragon's Avatar
Ummm... Paragon?
Old 09-04-2005, 07:34 AM   #10
Mie3R's Avatar
U can also polish the tyre using WD40 to get more traction. cheaper n easy. this is what the EP guys did
Mie3R is offline   Reply With Quote
Old 09-04-2005, 11:17 AM   #11
asw7576's Avatar
Why don't you use sponge tires for more performance or economical reason ?
For Singapore's climate I think Sorex 40 with Hard / Medium inserts.
Old 09-04-2005, 09:08 PM   #12
Dragon's Avatar
umm, why would foams give more performance?
I find rubber last longer, and have more constant performance...
however, am i right by saying that the lower numbers 20-28, have higher initial traction, but lose traction faster when they heat up, while higher ones like 30-26 have lower initial traction, but wont lose much traction when they heat up?
Old 09-04-2005, 09:29 PM   #13
Rubbers dont last longer for me! I was using a new set per day! If you have the car set up properly, you can use 1 set of foams for 2 days in parking lots. On a prepared surface you can run them for a lot of fuel runs. At the Nats last year we ran the tires starting at 57mm. and they lasted for 1 hour mains.
Old 09-04-2005, 11:49 PM   #14
asw7576's Avatar
Have you ever try foams tires ? Give it a try and you will appreciate it. Here is why :
1. No gluing -- c.a glue sux
2. More grip : for singapore climate 37 shore and 40 shore or combination.
3. definetely last longer than rubber.
BTW...... do you know how long is final with rubber tires ? With foam tires I have 45 - 60 minutes Finals.
Old 09-05-2005, 12:14 AM   #15
moot's Avatar
foam has disavantages too.
needs trueing
chunks
car is generally dirtier afterwards
and for grip,on a painted tennis court,use foams and see how you go.
Rubber Tyres Birky Rookie Zone 16 06-13-2013 05:01 PM
Rubber Tyres ??? A Ilievski Electric On-Road 4 09-13-2006 11:26 PM
New to Rubber Tyres Rody Electric On-Road 7 08-21-2005 02:21 AM
Foam tyres or rubber tyres at IFMAR? habicht Electric On-Road 1 06-16-2005 11:02 AM
HPI rubber tyres new or used penggoy R/C Items: Wanted to Buy 1 05-02-2003 04:51 PM
