Old 08-10-2014, 12:53 PM   #1
Default Mugen mtx3 clutch
Does anyone know where I can get a clutch kit for my mtx3??
Everyone is either on back order or discontinued? It seems to be the same number as mtx4. Also, does anyone know of any clutch I can use instead? Maybe an upgrade of sort?
Burgrc8b is offline   Reply With Quote
Old 08-10-2014, 02:18 PM   #2
Default Clutch condition
I thought the clutch was supposed to be in 4 pieces. When I took it appart.
It was in 4 equal pieces. The ones I see online are one solid piece. They are on BACKORDER everywhere. I have no clue what I'm gonna do?
Old 08-11-2014, 01:48 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
Was the MTX3 not the same as the MRX3?
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-11-2014, 03:30 AM   #4
choisan's Avatar
Except the size of the flywheel and 2 pinions
choisan is offline   Reply With Quote
Old 08-11-2014, 04:46 AM   #5
wingracer's Avatar
Trader Rating: 24 (100%+)
What parts do you need? There are four flyweights and one shoe.
Here's a shoe at amain:
http://www.amain.com/Mugen-Seiki-Clutch-Shoe-Red/p1910
Flyweights:
http://www.amain.com/Mugen-Seiki-Lig...tch-Shoe/p1908
Adjusting nut:
http://www.amain.com/Mugen-Seiki-Spr...ing-Nut/p19641
Spring:
http://www.amain.com/Mugen-Seiki-Clu...per-Hard/p1909
Thrust bearing:
http://www.amain.com/Mugen-Seiki-10x...Bearing/p17126
Nut:
http://www.amain.com/Mugen-Seiki-Eng...MRX-MTX/p17143
Flywheel:
http://www.amain.com/Mugen-Seiki-Flywheel-MTX3-4/p17344
Spring cup:
http://www.amain.com/Mugen-Seiki-Spring-Cup/p19640
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-11-2014, 04:51 AM   #6
wingracer's Avatar
Or from ashford:
http://ashfordhobby.com/SearchResult...Words=MUGH0769
http://ashfordhobby.com/SearchResult...Words=MUGH0766
http://ashfordhobby.com/SearchResult...Words=MUGD0603
Team Shepherd USA
Old 08-12-2014, 12:01 PM   #7
Default Mtx3 clutch
Thank you guys for all your help. I found it at AMAIN.
Can anyone explain to me the difference between a single clutch shoe that I ordered now and the 4 piece shoe that came with the kit? I know I have a clutch problem with this, the brakes are not stuck as it rolls properly, only starts to move at high revs. I am kind of new to onroad. The 4 piece that I pulled out of this does not look worn at all! Certainly not what I'm used to on my buggy. The clutch bell looks to be fine also. I ordered both of them anyway. One more thing I put it all back together double checking all of my clearances and tolerances and still have the same problem. Nothing is binding at all, I am not getting any low speed clutch engagement. I am going to try a single clutch shoe and new bell to match and hopefully it makes it right.
Old 08-12-2014, 12:29 PM   #8
The mtx3 has whats called a centax clutch, vs centrifugal clutch in your buggy. Those 4 weights dont contact the clutch bell at all, they expand outward and force a pressure plate that big 1 piece sits on, into the bell. Unfortunately the gaps needed to make a centax work right are very tight (youll need calipers to measure, not something you can eyeball). The reason its not engaging until late is either; you have the clutch nut adjusted too tight (that washer that fits over that spring tunes the engagement point/rpm), OR, you have the gaps set wrong with the bell sitting too far away and its just barely touching.
Giant655 is offline   Reply With Quote
Old 08-12-2014, 12:31 PM   #9
lil-bump's Avatar
Trader Rating: 83 (100%+)
The four pieces are the clutch weights, The single piece is the clutch shoe.
look here this should get you started.
http://www.serpent.com/news/10063/Bu...-3-Clutch.html
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
