Old 09-01-2005, 02:51 PM   #1
Justaneon's Avatar
Send a message via Yahoo to Justaneon
Default window openings
Is it a must to cut the windows out on a nitro car body?
Justaneon is offline   Reply With Quote
Old 09-01-2005, 03:06 PM   #2
Dreddlox's Avatar
Yes. Otherwise you would have a some serious heat build up. Very bad for nitro engines.
Dreddlox is offline   Reply With Quote
Old 09-01-2005, 03:08 PM   #3
Justaneon's Avatar
oops, i meant the side windows i have a 2" hole in the front and back windows
Old 09-01-2005, 03:13 PM   #4
Dreddlox's Avatar
Just more ventilation. If your engine temps are good, I would'nt bother.
Old 09-06-2005, 02:51 PM   #5
theRED5's Avatar
R/C Tech Charter Subscriber
and it makes it easier to pick up the car during pitstops.
theRED5 is offline   Reply With Quote
Old 09-06-2005, 04:34 PM   #6
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I usually cut out one window on the side of the motor / closest to the motor. That generally helps the cooling while not sacrificing body rigidity. Otherwise you will get a hotter motor and this means youll need to richen the mixture to help cool the motor more = less power.
-- Happy Tuning.
Artificial-I is offline   Reply With Quote
Old 09-06-2005, 06:08 PM   #7
AndyT 's Avatar
I found taking the side windows had about a 10 degree f cooling benefit after taking temps before and after using a temp gun.
AndyT  is offline   Reply With Quote
Old 09-07-2005, 01:26 AM   #8
theRED5's Avatar
Besides, the front end is going to wear out long before you have trouble with the roof.
My engine is worth more than the body....
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
Window Trim? Tire Chunker Painting, Designs, Graphics and Photography 1 03-26-2008 07:41 PM
Openings in GQ Drivers Program JosephatCRC Electric On-Road 3 12-06-2006 08:07 PM
Window Trim HiImATreeHugger Painting, Designs, Graphics and Photography 3 05-11-2006 05:28 PM
Window cutouts psbarger Painting, Designs, Graphics and Photography 4 07-07-2004 05:35 PM
window frames Rod M Painting, Designs, Graphics and Photography 5 01-26-2004 11:34 PM
