Old 07-22-2014, 06:21 PM   #1
RCNYWOLFTEAM's Avatar
Default Ofna Hyper Gt RTR
Chassis: 0.12" (3mm) thick aluminum, orange in color
Drive: Four wheel
Engine: .28 cu in (4.6cc) with pull starter
Exhaust: Polished aluminum tuned pipe
Radio: HoBao HT-2.4EF 2.4GHz FHSS 3-ch with metal gear steering servo
Radio Tray: One-piece for quick removal of battery box, servos and
receiver box
Suspension: King pin hub type with 2mm diameter front sway bar and
2.8mm diameter rear sway bar, solid front and rear arms for less
flex, captured hinge pins
Shocks: 17mm black coated Big Bore short stroke
Shock Towers: 0.16" (4mm) thick aluminum, orange in color
Differentials: Two oil-filled
Bumper: Front foam
Ball Bearings: Full set, rubber sealed
Body: Prepainted rally
Wheels: Black mesh 4" (102.7mm) diameter
Tires: Semi slick soft rubber
Caster: Adjustable front and rear, caster/toe-in refers to the angle
of the front suspension when viewed from the side of the car in
relation to the chassis
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
RCNYWOLFTEAM is offline   Reply With Quote
Old 07-27-2014, 06:36 AM   #2
turbonutt's Avatar
subscribed. I've been seriously considering this but have been waiting to here some reviews
Hobby Revolution Team N.E.R.D. driver
turbonutt is offline   Reply With Quote
Old 07-28-2014, 04:45 AM   #3
Fluke's Avatar
same here. i was looking for a gt this year and having owned an hyper7pcr in the past, i've been looking around for user reivews but only found 2 videos on youtube
Fluke is offline   Reply With Quote
Old 07-28-2014, 08:26 AM   #4
ill Make One Soon i Should Be Getting Mines Today
Old 02-11-2015, 09:49 AM   #5
rcmattster1971's Avatar
Any one with new info on this car? I have just ordered one. I know it isn't up to par with the pro units but it should be fine for street bashing, anyone have opionions or experience with this unit?
Traxxas Jato(2), Hyper 7's(2), Team Associated MGT 4.6, Vintage Kyosho Javelin, Hyper GT Nitro with Novarossi, Axial Yeti 2.2 fully loaded, Axial Wraith full loaded 5.0
rcmattster1971 is offline   Reply With Quote
Old 05-11-2015, 10:32 AM   #6
angrymelon's Avatar
Has anyone raced with one of these yet? I like how inexpensive the car is, but worry it won't be up for the task if pushed hard on the track.
-=Ryan B=-
VBC Racing USA - Team Powers USA
PDX On-road: https://www.facebook.com/groups/onroadracing/
angrymelon is offline   Reply With Quote
