Spektrum/m11 fail safe issue. >
Old 07-13-2014, 07:06 PM
Trader Rating: 17 (100%+)
Default Spektrum/m11 fail safe issue.
I'm running a spektrum receiver with a M11 radio. When the signal is lost it goes into a full throttle lock instead of brake. I cannot seem to figure out how to reverse it. Please help.
Mr.A Morris is offline
Old 07-13-2014, 08:27 PM
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
https://www.spektrumrc.com/ProdInfo/...structions.pdf
Click on the instructions for binding process, scroll to page 10.
Last edited by FREELANCE_RCer; 07-14-2014 at 07:20 PM. Reason: DSM System Spektrum Binding Process
FREELANCE_RCer is offline
Old 07-13-2014, 08:43 PM
Geezatec's Avatar
Changing REV. Or DL manual on internet
Attached Thumbnails Spektrum/m11 fail safe issue.-image.jpg
Geezatec is offline
Old 07-13-2014, 09:01 PM
Geezatec's Avatar
Oooopppsss!!! First post was for the M8. This one the for the M11
Geezatec is offline
Old 07-14-2014, 04:47 AM
Roelof's Avatar
Spektrum module! No way the menu of the transmitter will work.
Indeed a rebind of the receiver is needed with the right setting of the controls to get the preverb failsafe. (I always use the trim to set some brake when binding the receiver)
Roelof is offline
Old 07-14-2014, 08:05 PM
The radio in use is the Sanwa/Airtronics M11, the module is removable and can be replaced with other compatible module like the spektrum.
It does'nt mentioned a Spektrum DX radios that that can be searched on the menu of the transmitter for binding process.
Re-binding process to re-set fail safe mode vs servo reversing.
Normal Operation:
Throttle trigger is pulled: Carb opens, car runs.
Throttle trigger is pushed: Carb closes, brake is applied then car stops.
Servo Reversed:
Throttle trigger is pulled: Carb closes, brake is applied then car stops.
Throttle trigger is pushed: Carb opens, car runs.
I don't think this will solve the Fail Safe problem, it just makes the conditions worse.
Old 07-16-2014, 10:05 AM
@Freelance your first post did the trick! No longer going WOT. It goes to natural still no brake but better than the other option LOL... Once I get a spring on there it should pull a little brake.
