Old 08-23-2005, 10:17 AM   #1
Default Stuck mounting screw
My engine mounting screw is stuck. I have to use an alan jey to get it out and the head is stripped. BTW what is that kind of head called an alan head, hex head, what is it? Anyway it has thread lock on it too. The other 3 came out with no problem, but this one is stuck. How can I get it out?
rcburner is offline   Reply With Quote
Old 08-23-2005, 11:25 AM   #2
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Use a dremel to cut a slot in it and use a flat blade screwdriver.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-23-2005, 11:32 AM   #3
Data's Avatar
socket head
Data is offline   Reply With Quote
Old 08-23-2005, 01:43 PM   #4
Rapid Roy's Avatar
If you already have 3 out, jamb an hex wrench or phillips screwdriver into the stripped head. Then turn the motor and motor mount on top of the chassis. You should be able to crack it loose.
Rapid Roy is offline   Reply With Quote
Old 08-23-2005, 02:17 PM   #5
You know that will work, but I'll have to take alot of things off the chassis inorder to turn the motor, and I want to avoid that.
Old 08-23-2005, 02:25 PM   #6
I have this imitation dremel I bought from Kmart, and I tried cutting a slot. The piece broke off and hit me in my forehead. I guess I have to buy a better disc. Better my head than my eye.
Old 08-23-2005, 02:38 PM   #7
You should always wear eye protection when using a dremel. Also, try and hold the dremel straight, so the disc doesn't bind and cut slowly.
Old 08-23-2005, 11:40 PM   #8
dct147's Avatar
This happened to me once too.
a kind soul helped me out on the track.
This is how it was done.
He positioned a flat head screwdriver on the outside of the screw. what i mean is at the edge of the head of the screwdriver.
knock it a few times to loosen the screw. reposition the screwdriver to knock towards centre of the screw. knock it and make a dent deep enough for u to use a screwdriver to get it out.
i hope i`m clear about it.
dct147 is offline   Reply With Quote
Old 08-24-2005, 06:24 PM   #9
AndyT 's Avatar
Its certainly very important to make sure youre wearing eye protection whenever using a Dremel, Ive certinaly had a few times where I`ve been glad to have had eye protection on
When using the cut off disc, try and avoid any twisting...the twisting causes the cut off discs to shatter rather quickly.......when buying the discs I`ve found the reinforced ones are much more robust/durable than the standard ones and will last heaps longer.
Cheers
AndyT  is offline   Reply With Quote
Old 09-07-2005, 01:38 AM   #10
theRED5's Avatar
R/C Tech Charter Subscriber
While we're talking about Dremel's, why can't they rotate the other way? Then anything coming off the wheel would go away from your face.....
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 09-07-2005, 09:25 AM   #11
Data's Avatar
i think the dremel was designed by a lefty.
Old 09-07-2005, 09:46 AM   #12
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Take a drill bit almost as large as the head of the screw, drill the head off then remove the engine and mount. There will be enough screw left sticking out to grab with some Vice grips.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 09-07-2005, 09:49 AM   #13
Actually its the nature of electric motors. Manufacturers wind them all the same way so they all run the same direction. You dont need to go to the Lef`torium to get one thats runs a different direction!
mounting screw size for orion mini baja motor. huskerdually Micro and Mini Scales 2 04-30-2008 11:42 AM
Mega ZX12 Screw stuck in head BigPapa Nitro On-Road 3 01-21-2008 04:56 PM
Engine mounting screw catkchun Malaysian R/C Racers 28 10-19-2007 07:31 AM
XRAY - Wheel Mounting Screw/Washer Kit drx R/C Items: For Sale/Trade 6 05-13-2006 12:57 PM
Have you ever had a screw stuck that just won't come out? tbeardmore Rookie Zone 17 04-24-2006 11:47 AM
