Old 08-21-2005, 07:44 AM   #1
Dragon's Avatar
Send a message via ICQ to Dragon
Default Engine Help Please! :(
Hi, recently got a OS TR P T, got a problem....
It idles properly, however when i pull the throttle slightly abt 30-40%, the engine boggs out.
I have slowly tried to richen the fuel/air mixture screw even till the point it almost dies but it still cuts out when i slowly pull the trigger...
is there something else i can adjust? i have run out of options after trying for 4 hours....
TIA
Dragon is offline   Reply With Quote
Old 08-21-2005, 07:57 AM   #2
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
If the engine bogs then you should have leaned it. Try going back to your original settings and lean the low-end some and see how that goes.
BTW we have a nitro engine forum just above.
Artificial-I is offline   Reply With Quote
Old 08-24-2005, 08:36 AM   #3
Dragon's Avatar
is there? i cant seem to find it...
dun mind posting a link to it? many many thanks
Old 08-24-2005, 12:58 PM   #4
Edwards's Avatar
Wink
Yep, definitely lean the engine if it's bogging down. It's all audible, if it sounds like it's gurgling and there is lots of smoke and oil coming from the stinger, then lean it out. If it's sounding starved and struggling, then richen it. Unfortunately, the two sound very similar and are hard to distinguish, if in doubt, richen it. The rich/lean mixture are affected by the temperature of the air/enging so give it a few minutes at idle to warm up, especially if your running it in the cold.
Thanks,
Chris
Edwards is offline   Reply With Quote
Old 08-25-2005, 09:22 PM   #5
Mie3R's Avatar
sounds like the engine is too rich or the mixture is not in right position. if everything seem to be fine, then check the turbo plug. change to other no. will help u finally.
Mie3R is offline   Reply With Quote
Old 08-25-2005, 09:27 PM   #6
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Link to it!
http://www.rctech.net/forum/forumdisplay.php?f=71
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-25-2005, 09:30 PM   #7
TIA
Also try a hot plug, unless it is above 100 deg`s. I run hot always in the 12 engines.
Old 08-25-2005, 11:56 PM   #8
Dragon's Avatar
whats the difference between hot/cold?(if got such a thing) plugs?
hot for hot weather? or burn hotteR?
me using 25% blue thunder sport....
Old 08-26-2005, 03:09 AM   #9
pme
pme's Avatar
Default carb
carb failure... try cheking your carb maybe its no good for compression or it may have leaks
pme is offline   Reply With Quote
Old 08-26-2005, 03:11 AM   #10
Dragon's Avatar
Omg I have been trying to get my car to move like for 5hrs and i still cant seem to solve the problem....
i have tested mixture needle like from all the way in to all the way out.... which means thats not the problem....
is there something else that can cause it to cut out when i pull the trigger?
clutch engaging too early??
using the wrong pipe?? (im using the shark 5.2mm)
fuel lines too short??
Oh and i noticed that sometimes when trying to start the engine, it can sometimes run in the reverse direction! is that bad?
I am darned stressed and sad now....
Old 08-26-2005, 03:24 AM   #11
Dragon's Avatar
Heres the top view of it... if u notice anything wrong... please let me know!
Engine Help Please! :(-top.jpg
Old 08-26-2005, 03:33 AM   #12
Edwards's Avatar
Thumbs down
Damn brother, that is a SERIOUS problem. An running backwards is NOT GOOD! I mean seriously, seriously not good. The only thing I could think of is the ignition timing being wrong due to an incorrect/faulty glow plug for your engine/fuel combination.
Thanks,
Chris
P.S: That's a nice car you've got!
Old 08-26-2005, 03:35 AM   #13
Edwards's Avatar
By the way, is that a FUEL FILTER you've got coming out of the exhaust-fuel tank line? Rip it out right away. That line should just be a straight connection between the fuel tank and the tuned pipe. Only have a fuel filter on the fuel tank-engine line, and make sure it gets cleaned alot.
Thanks,
Chris
Old 08-26-2005, 03:37 AM   #14
Edwards's Avatar
Also, check and clean your air filter, check and clean the clutch, check and clean the engine and, if you know how, strip it down completely. ONLY DO THIS IF YOU KNOW HOW!!!!
Thanks,
Chris
Old 08-26-2005, 03:41 AM   #15
Dragon's Avatar
ARrrghhh how how???
Running backwards is bad??? will it get damaged?????
ARRGGHhhh!!!....
ARGGGGGGGHHHHh!!!!
The previous owner said he changed to a OS P8 cold plug... but i noticed that there is no shim there between the plug and the head... is that another problem??
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 04:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
