Old 09-21-2002, 03:42 PM   #1
Default Head button interchangeability?
Can I interchange head buttons from different engines? The reason why I'm asking is because some of my engines have a thick head button and others have a thin one. Is it ok if If I mix?
If it helps, they are mt-12, sx-12, and rs12 engines.
Thanks.
rcpilot is offline   Reply With Quote
Old 09-22-2002, 01:31 PM   #2
NTC3NUT's Avatar
Be carefull with the thickness. Both the thin & thick can be used on the long rod engines (the piston sleeve protrudes from the crankcase). You can only use the thick button on the short rod engines (the piston sleeve is recessed into the crankcase).
NTC3NUT is offline   Reply With Quote
Old 09-22-2002, 04:28 PM   #3
Thanks for the info.
V-SPEC Head and button on a VG ? shockripple Nitro Off-Road 3 12-06-2007 03:59 AM
Anyone know what head button and carb? BrainMuffin Electric Off-Road 3 09-16-2006 10:11 AM
Sirio Head Button jhec23 R/C Items: For Sale/Trade 0 03-18-2005 11:19 PM
Want .21 head button. shadmaster4 R/C Items: Wanted to Buy 0 06-19-2004 11:03 AM
Looking for Head and Head button for MT12 std plug Deltaman R/C Items: Wanted to Buy 0 07-15-2002 10:53 AM
