Old 08-24-2005, 03:34 AM   #16
VenomWorldOrder's Avatar
don't mean to burst the kv1 bubble but with the mtx4 comming out you will find many cheap mtx3's on the market. if oyu are after a cheap second hand car i would recommend the mtx3 over the kv1 as it is a newer car, quicker car and parts are just as available. also setups for the mtx3 are more up to date.
VenomWorldOrder is offline   Reply With Quote
Old 08-24-2005, 12:48 PM   #17
afm
afm's Avatar
Originally Posted by Bundy_Bear
Also are you able to shed some light onto what parts will be interchangable with the G4?...............
BB
Bundy Bear
I checked and found that parts interchangeable with G4 are:
-Front steering blocks
-Differentials
-Belts, pulleys
-Front and rear lower suspension arms, with slight differences in shock position options. On the KV1 lower and upper, on the G4 inner and outer
-Front upper susp. arm
-Rear uprights
-Universals
-Pivot Balls
-Wheel hexs
So there should be no problem with most wearable parts availablity...only thing I need to check is spurs and pinions compatibilty...I think the Trinity reflex parts should be their match.
Looks good to me...best RTR I've seen so far...fully loaded with optionals
I reafirm it is a Ready To Race car, more than a Ready To Run...just cahnge the .15 engine with a good .12...and hit the track.
AFM
afm is offline   Reply With Quote
Old 08-25-2005, 01:46 AM   #18
Bundy_Bear's Avatar
Originally Posted by afm
Bundy Bear
-Differentials
-Belts, pulleys
-Rear uprights
-Universals
-Pivot Balls
-Wheel hexs
AFM
AFM: Do you know if KFactory are likely to bring out spares for the KV1?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 08-25-2005, 04:39 AM   #19
Bundy_Bear's Avatar
Heavy: I took your advice an went down to Mt Gravatt an checked it out in the flesh...
Everyone:
Firstly i would like to thank the LHS for allowing me to see a KV1 in the flesh. As AFM has already put it this car is "Ready To Race"! I was a little disappointed to see the front diff weeping as it did with the V1R. It did look a little fragile to what i remember the Kyosho being like. Having said all of this, i can see this car being a great "Club" car, but as Venom has said it will struggle against the latest generation cars.
If anyone has one an had some track time, can you please add your feedback
BB
MissMooRC Racing
Old 08-25-2005, 07:14 AM   #20
afm
afm's Avatar
BB
Yes they have them. All part numbers are in the car's manual. It depends on every distributor to carry them.
On a side note:
The exact car from which it is based, is the Trinity Reflex / NT / Team Only.
As you know, that was the first car Team Magic made before the G4.
So they've relaunched it as the best possible Entry Level Ready To Race 200mm car. That is the targeted market.
Expect performance to be similar as to what the Reflex had in it's time.
AFM
Old 08-25-2005, 11:32 AM   #21
afm
afm's Avatar
Actually the more i look at the KV1, and the more I search information, the more it confirms me that it is a re-run of the Trinity Reflex NT with a lot of the optionals of the Team Only version, and some improvements of it's own.
This is a car that uses all the top technology of around 2002, 2003 era, and was a direct competitor to the Serpent 705, Yokomo GT4, Kyosho V one R, RR
Mugen MTX2.
In 2002 in the hands of Josh Cyrul it placed second in the finals of thefirst 200mm World Cup held in Cincinati.
You can read the reviews and articles of the time here:
http://www.findarticles.com/p/articl...02/ai_n9038084
http://www.rc411.com/pages/reviews.php?review=22&page=3
http://www.rcnitro.com/articles/tunercar.asp
So it is a very capable high end RTR.
AFM
Old 08-29-2005, 03:58 AM   #22
Bundy_Bear's Avatar
Default Bump!
I tried to have a look at one in action this weekend, but the guys running them didn't show up
BB
MissMooRC Racing
Old 03-08-2006, 03:18 AM   #23
Bundy_Bear's Avatar
Is anyone running one of these cars? Can you please provide some feedback?
TM (KFactory are subsidery of TM) have released RTR versions of the G4, so what does this mean for the KV1?
I am also curious to know if the clutch supplied with the kit can only be used with a SG shaft engine or a threaded shaft like a OS Cv-x or a Force .12 etc?
BB
MissMooRC Racing
Old 03-08-2006, 04:25 AM   #24
hav_lova's Avatar
I agree with VWO, who i can never seen or spoken to in my life and we do not know each other ( )
I've run a reflex for a race season and can say its a fantastic beginers car, but it lacks compared to any newer cars.
Btw, just some input. On my reflex, i have found i can also fit G4 belts, and hubs, and KV1 fuel tank clutch belts spurs. virtually everything is interchangable so i don't have much trouble with part support here in aus.
A tip for anyone running a KV1/reflex, ditch the stock rear shocks and put xray shocks on the rear and you can get a lot more droop out of that sucker!
but summing up, the reflex was a great learning curve for me, and for what you get as a RTR its a fantastic car. and looks rather nice on the shelf, which is where mine is going now
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 03-08-2006, 04:30 AM   #25
hav_lova's Avatar
Btw, i want to add this, the reflex/KV1 doesn't lack in any major improvements in r/c, it has it all. Universal dogbones, a front one way option, centax option, low CG, a great 2 speed (i NEVER stripped any gears EVER), very nice brakes,
serpentrc.com.au
Old 03-08-2006, 12:34 PM   #26
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Thumbs up
I think the KV1 is about same as Trinity Reflex which runs pretty good. I highly recommend it.
Mike Schumacher is offline   Reply With Quote
Old 03-09-2006, 03:57 AM   #27
hav_lova's Avatar
...it is the same... exactly the same.
serpentrc.com.au
Old 03-10-2006, 10:59 PM   #28
Helix70's Avatar
Any of you guys got an electronic manual for the Trinity NT? I need some help with the two speed (mine has grub screws and ball bearings instead of rollers, and I need to know how to set it up). Also, where would I buy some clutch shoes (3 shoe clutch, not centax). I am slowly learning where all the bits come from to make up the NT (K-Factory etc).
Thanks,
Josh
Helix70 is offline   Reply With Quote
Old 03-10-2006, 11:44 PM   #29
hav_lova's Avatar
Thanks,
Josh
Which page do you need?
serpentrc.com.au
Old 03-11-2006, 12:07 AM   #30
Helix70's Avatar
The 2 speed page if you can (how to set/adjust), thanks a heap! Also, if it isn't too much hassle, the clutch/flywheel page?
Cheers,
Josh
F/S KFACTORY MONGOOSE G4 Roller bill marchant R/C Items: For Sale/Trade 0 08-02-2006 09:23 PM
MONGOOSE KFACTORY UPGRADES F/S bill marchant R/C Items: For Sale/Trade 2 06-26-2006 07:34 PM
Kfactory G4/Mongoose 3mm Chassis NIB rodneybarrett R/C Items: For Sale/Trade 2 05-24-2005 10:23 AM
Problem with G4 kfactory front one way?? mario_vk Nitro On-Road 9 01-06-2005 04:24 PM
G4 with kfactory speedy100 R/C Items: For Sale/Trade 2 05-13-2004 10:19 PM
