Old 05-22-2014, 02:16 AM   #1
Default help identifying a serpent 1/8
Hi guys, I have picked up an older serpent 966 to get into 1/8 racing but it looks like there were a few models (TE, Evo), is there a big difference between them and how do I know which one I have?
I am trying to find a setup to start with, any suggestions for a technical high-ish traction circuit? I looked on the serpent website, what is a good one to try?
thank you
Fly'n Fish is offline   Reply With Quote
Old 05-22-2014, 09:12 AM   #2
dan_vector's Avatar
Trader Rating: 27 (100%+)
thank you
Original 966 had short, narrow upper Alu suspension holders and rccx shocks
966 evo had new bearing blocks allowing the bearings to be mounted within plastic bushes. Not a vast change over original 966
966-TE had a big change. RCM shocks, Split radio plate for flex. New wider front upper suspension blocks (roll centre change) as well as a change from rear upper wishbone to camber rod with new camber bracket. It also included the new SL8 gearbox. It also had rear lower shock extensions to change the shock angle.
966-TE v2 just added the Centax True Motion Clutch.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 05-22-2014, 09:13 AM   #3
dan_vector's Avatar
Post a couple pictures of front and rear end and I'll tell you which version you have!
