Old 08-20-2005, 09:57 AM   #1
Default servo problem. Please help!
some how the servo is breaking when i put full gas and when i put the break on it gives it gas. how do i fix this. (is there a way to reverse the servo?) if so PLEASE REPLY i need all the help i can get.
Please and Thank You!
cars.cars.cars is offline   Reply With Quote
Old 08-20-2005, 10:07 AM   #2
There's a reverse function on pretty much all radios. What radio do you?
brianlt27 is offline   Reply With Quote
Old 08-20-2005, 10:23 AM   #3
i have the futaba magnum 3pm-fm radio and a servo that came with it and for steering im useing futaba digital S9350 coreless motor
Old 08-20-2005, 05:15 PM   #4
Rapid Roy's Avatar
Look up "servo reversing" in the index of the manual for your radio.
Rapid Roy is offline   Reply With Quote
Old 08-22-2005, 01:02 AM   #5
AndyT 's Avatar
With the 3PM go thru the menu till find the one that says REV-ST.....this will reverse the steering servo (use the + or - key to reverse the direction)......then use the CH key to access the menu to reverse the throttle.....it`ll say REV-TH (then again use the + or - key to set it correctly)
Cheers
AndyT  is offline   Reply With Quote
SERVO PROBLEM lancerevo22194 Micro and Mini Scales 11 07-23-2008 04:17 PM
Servo problem ???WTF Please TRFTIM Electric On-Road 1 11-20-2006 03:03 PM
ESC or SERVO Problem kimbalion7 Electric On-Road 4 02-02-2006 04:27 AM
servo problem wothrottle Electric On-Road 0 09-29-2004 06:24 AM
servo problem wahturi Nitro On-Road 7 12-25-2002 10:48 AM
