Old 09-19-2002, 10:18 AM   #1
VONEREFLEXR's Avatar
Default What does shore mean?
Anyone have an answer for this
VONEREFLEXR is offline   Reply With Quote
Old 09-19-2002, 10:43 AM   #2
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
"Shore" is another word for "hardness" when refering to tyres.
Example - 30 shore, 40 shore, 50 shore etc etc...
The lower the shore the softer the tyre. The higher the shore to harder the tyre.
Example - 35 shore tyres are softer then 40 shore tyres.
Michael_T is offline   Reply With Quote
Old 09-19-2002, 11:50 AM   #3
Data's Avatar
Default Re: What does shore mean?
Shore (or Durometer) test is the measurement of the resistance of the rubbers/elastomers toward indentation. It has two scales, Shore A and Shore D. Shore A is usually used to measure softer materials, like foam and rubber tires used in R/C cars.
Note that the measurememt will change over time or if the material being measured has changed in thickness. A brand new tire will have a higher reading if you measure it again three months later or after 20 laps (3 laps at Revelation ).
Data is offline   Reply With Quote
Old 09-19-2002, 12:01 PM   #4
thanks for all the wonderful information, Sir!
ME-student is offline   Reply With Quote
Old 09-19-2002, 12:43 PM   #5
Michael_T's Avatar
Default Re: Re: What does shore mean?
Great info
Here is a question you might be able to answer : Why are a set of tyres that come out of a box brand new never the same shore as rated on the box? Is it because over time the tyres will have changed readings (as you mentioned above) or is it because of the different techniques/durometers used when measuring the tyres?
Question 2:
If you do have two identical 40 shore tyres both 60mm and both brand new. You true one down to 55mm and the other down to say 58mm - will the shore ratings now change for each tyre? -In other words, the 55mm tyre will actually have a higher rating (harder) then the 58mm tyre?
Old 09-19-2002, 02:42 PM   #6
Shore - The land along the edge of an ocean, sea, lake, or river; a coast.
Land; country. Often used in the plural: far from our native shores.
Land as opposed to water: a sailor with an assignment on shore.
LoL.....J/K..just trying to add some humor to this post
DookieBooty is offline   Reply With Quote
Old 09-19-2002, 03:31 PM   #7
Data's Avatar
Default Re: Re: Re: What does shore mean?
Originally posted by Novarossi
Great info
Question 2:
I guess the rating on the box applies to the foam material before they were turned into tires. When a manufacturer rate the material, they would follow the guidelines per ASTM standards. Meaning they would obtain a specimen from the batch with specific dimensions (usually a square/rectangular block or disc with a certain thickness) and tests the specimen under a specific condition/method per the standard. This specimen, I am sure, does not have the same shape and sizes as the foam tires one took out from the box.
A thin (about 7mm), curved piece of foam, reinforced by a semi-rigid plastic (the rim) would have a different reading from the specimen that was tested by the manufacturer even if it is the same material. The reading can also be affected greatly by how the material is able to deform under stress. Notice the readings between the center of the tire and the edges of the tire are different? At the center, the foam could and would deform in all directions, at the edges, the deformation is limited to one side.
I would expect the 55mm tier to have a higher reading when tested at the same spot because it has less material to deform and is closer to the reinforcing rim.
Shore rating gives an idea of relative resilience of various grades of rubber/foam but it does not give any information on properties like wear or abrasion and they could be different between manufacturer even if the Shore rating is the same. I wouldn’t worry too much about this Shore rating thing and I don’t understand why the manufacturer even bother to put it on the box since it is really meaningless to us. A simple “Really Really Hard”, “Really Hard”, “Medium”, “Really Soft”, “Really Really Soft” rating should suffice, my opinion anyway....
Old 09-19-2002, 03:38 PM   #8
Data's Avatar
@$%^*&^$%^#%[email protected]#$! :X
Old 09-19-2002, 04:15 PM   #9
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I thought that the possibility of getting a tire with the spec shore rating, would depend on how much effort the manufacturer put into grading. From my understanding, foam tires regardless what their shore rating, start life as a single sheet of foam where different sections of the foam are different in hardness. The sections are then cut to accordance and graded and regraded. If you have a good manufacturer such a GRP, they will grade 2 or 3 times before a shore rating on a tire is cement. Grading isn't perfect but the more you do it, the better your chances are at maintaining consistency in tire wear and grip. You would have to spend an arm and a leg for tires that are the shore rating listed on the package because the manufacturer would have to throw away the tires that didn't have the correct shore rating.
Racing4Evo is offline   Reply With Quote
Old 09-24-2002, 09:33 AM   #10
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
That is right - they measure when it's a sheet, not on the rims.
Part of the reason for the variance is that the rubber manufacturers don't have that much precision in their manuf process - Jaco's supplier doesn't have 40 shore (C) rubber, they have 38-50 shore (C), so what he does is he finds areas on the sheet (48" square) that are the grades that he wants for each rating of tire. Some will be Ppl, some will be Double Ppl, etc.
Jaco uses the C rating of Shore since that's what he gets from his supplier.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Choosing tire shore #. ewallace Nitro On-Road 7 07-30-2008 03:56 PM
Foam shore elche_83 Australian Racing 5 02-26-2008 04:42 AM
NEW 1/5 SCALE PMT TIRES 15 SHORE Perez R/C Items: For Sale/Trade 1 07-15-2006 12:41 AM
Which shore tires for MTX-3 22dasher Nitro On-Road 8 08-02-2005 10:36 AM
Shore Ratings Nrctc3 Nitro On-Road 3 12-08-2003 02:14 PM
