Old 05-11-2008, 11:48 PM   #721
The GPX-4 is a great handling car. But concentrate on loosening up the drivetrain.
Genius is offline   Reply With Quote
Old 05-12-2008, 01:14 AM   #722
skengines's Avatar
Trader Rating: 226 (100%+)
ok
skengines is offline   Reply With Quote
Old 05-27-2008, 08:44 PM   #723
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Originally Posted by ProE View Post
Does anyone know when the new kit will be out(GPX-?).
Any news on the new car??...............
Sworkz EVOII LE/Hobbywing/Protek
Roche Rapid F1/Hobbywing/LRP
Taffyjnr5 is offline   Reply With Quote
Old 07-04-2008, 07:07 AM   #724
Taffyjnr5's Avatar
Old 07-04-2008, 08:41 AM   #725
godzukihop's Avatar
Trader Rating: 31 (100%+)
Heard that it is still a while away.
godzukihop is online now   Reply With Quote
Old 07-09-2008, 09:19 AM   #726
plipitkc's Avatar
Default Slick Track Diff Oils for GPX 4 RTR
I just got this car RTR version and am setrting it up for a medium slick parking lot 75 x 100 with 85 ft straight and tight turns. I have 4 gear diffs in both ends and a couple of questions. Yellow springs front and blue in rear.
Common sense says start with 3,000 in both but after reading some of this post, i'm questioning that decision.
On my CD3, I'm running 3,000 rr & 10,000 frt with 40 wt and yellow springs all around. Power is a Jammin .12 on foams. (38 frt & 45 rr)
1. What weight shock oil is a start point for this condition of track?
2. What Diff oils are reccemmended for frt and rear?
3. Any reccommended starting points on foam tires Track temps are between 85 and 145 F?
Later
Phil
Go Fast, Turn Left, and Don't Spare the Horsepower Elmo. Rubbin' is Racin'; Mugen Rules, Elmo Racing & Georges Hobbies, Ricky Racer Lidz, Stuck On You Graphics.
plipitkc is offline   Reply With Quote
Old 07-09-2008, 02:18 PM   #727
Taffyjnr5's Avatar
Hi,
I run this car in RTR (pullstart class) in Oz and I run:
Shocks: 40wt oil in shocks all round
Diffs: 0K rear diff/100K front (acts similar to a spool)
Springs: Hobao/Ofna yellow front/Mugen purple rear
Tires Jaco (Nitro shoes) 38 front/Jaco (Nitro shoes) 40 rears (I true the front tires 2mm smaller than the rears when new as the rears wear much quicker)
Most of the time setup is trial and error and by feel.
Old 07-09-2008, 02:44 PM   #728
godzukihop's Avatar
Originally Posted by Taffyjnr5 View Post
Hi,
Did you modify the hole in the shock piston? I found 40wt too thick with that small shock hole.
Old 07-09-2008, 03:24 PM   #729
plipitkc's Avatar
What size do you need to drill the hole to? Is there different pistons we can purchase?
Phil
Old 07-09-2008, 03:44 PM   #730
godzukihop's Avatar
Phil
If you back track this thread, the best information on the car came from a guy from France. He has 2 1.2mm holes in each piston. You enlarge the .8mm hole to 1.2mm and then drill another 1.2mm hole. I have not found any aftermarket pistons.
Old 07-10-2008, 05:44 AM   #731
Taffyjnr5's Avatar
Hi,
Yes I did sorry I went 1mm all round. I have not tried 1.2mm.........
Old 07-10-2008, 06:05 AM   #732
godzukihop's Avatar
Hi,
What do you run for rear camber? I had to go to -3deg. to get even tire wear, or else the outer edges wear down too fast.
Old 07-10-2008, 10:59 AM   #733
Taffyjnr5's Avatar
Hi,
Not sure what I have got I have not had it on the setup station for a while I just adjusted to get even tire wear like you said. I am also looking at testing some Kyosho rear uprights/hubs so I will let you know how that goes.......
Old 07-10-2008, 11:59 AM   #734
godzukihop's Avatar
Hi,
THX, I will be waiting to hear how that goes.
Old 07-28-2008, 09:56 AM   #735
Taffyjnr5's Avatar
Default Pro
Hi,
I am looking at putting my GPX-4 Pro chassis back together for a run so see how it goes. Don't know what engine to run may source a Murnan to try in it.........
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
