Old 05-01-2007, 05:19 PM   #631
vc05hdt's Avatar
Originally Posted by Pattojnr
Happy birthday to you, Happy birthday to you, Happy birthday Mark.
and ironic that your G4S shows up on your birthday. see ya sunday
Yes it is ironic and now six cars hidden from wife in shed! Thanks for the wishes Paul
vc05hdt is offline   Reply With Quote
Old 05-02-2007, 02:20 AM   #632
Bundy_Bear's Avatar
Hi
I am still none the wiser at the moment as to what HoBao are doing with the GPX4. I have had four emails back from retailers confirming they have stock and believe they are still current. But have had no reply from either Ofna or HoBao at this stage.
Working in retail, i know that often the stores are left in the dark, Often they are not told a model is obselte until they go to reorder the item.
===> 3-5-07 Just had an email back from Tower Hobbies, they have just discontinued the GPX4 from their Ofna product range, the car hasn't been discontinued by Ofna.
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 05-05-2007, 06:00 AM   #633
Default GPX4 PRO SALE
I got a new gpx4 pro only had max of 2lr of 16% comes wid starter box wid charger, glow plug igniter and charger wid that and venom squeeze bottle. Bmw m3 shell, wat u see is wat u get and the hobao tools as well. Serious buyers only!!!, Regretful sale due to buying a new real car. call me Roger on 0423452402 ill post some photos have a look give me some feed back plz
i dont wanna sell i was going to start racing i was going to change the belts and change the front diff and get a new motor novarossie to race in pro class
Hobao GPX4 Pro-dscn4209.jpg   Hobao GPX4 Pro-dscn4208.jpg   Hobao GPX4 Pro-dscn4207.jpg   Hobao GPX4 Pro-dscn4206.jpg   Hobao GPX4 Pro-dscn4215.jpg
jr-mods is offline   Reply With Quote
Old 05-05-2007, 06:13 AM   #634
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Bundy_Bear
Hi
BB
Damm shame they are a nice car to drive!!!!!.......
Taffyjnr5
Taffyjnr5 is offline   Reply With Quote
Old 05-05-2007, 08:43 PM   #635
Originally Posted by vc05hdt
MTX3 belts substitute for original belts. I am using side and rear, have not tried front yet. They might be getting scarce. Let us know if you get them and where from.
hey vco5hdt thanx for your reply I'll get one mtx3 side belt from rcboyz.com. for my gpx4
alexrgz is offline   Reply With Quote
Old 05-06-2007, 03:42 AM   #636
vc05hdt's Avatar
No Problem
Old 05-07-2007, 03:13 AM   #637
Joehwee's Avatar
Originally Posted by razzor
hi guys
Maybe this is mentioned before but over the weekend i spoke to a buddy who was getting hes GPX4 setup at the Nats and we were looking at different options for the front end.I loan him a G4S 32T front spool and it fits.The front oneway on the GPX4 is also 32T.
I am not sure how your friend managed to fit the G4S 32T fron spool into the GPX4 with some machining work. After reading your post, I went to buy the G4S oneway + front Spool from my LHS and no way it can fit the GPX4, end up i have to lathed approx 2-3mm off each side to get it to fit. So if any of the GPX4 owner out there that want to try a spool, please note it is not a direct fit.
Joehwee is offline   Reply With Quote
Old 05-08-2007, 09:49 PM   #638
Swamp Rat's Avatar
Spool = locked diff
just pack it solid with blue tac
LCRCCC. inc. The Greatest Club in QLD.
Come see our great new layout.
Schumacher Mi6 x 2,Yokomo BD7, Roche F1, SP F1 x2,Serpent SF2 F1, MO5 mini, M03 Mini, Corally F1 on Rubber, Futaba 4PX,
Ax10, SCX10, Joker Visit : www.lcrccc.org.au
Swamp Rat is offline   Reply With Quote
Old 05-13-2007, 01:59 AM   #639
hooked_on's Avatar
Hi
Picked up my RTR GPX4 yesterday afternoon thanks to the guys at Budget Hobbies. Installed my Spektrum and pulled the diffs down and reoiled them with siliconne oil.
Had a few issues though... the brake pads were not glued to the alloy parts and werent aligned between the two guides on the bulkhead. This now rubs a little, but i hope as the pads scrub in it will free up.
The thottle linkage seems to be an issue now. The stock servo doesn't appear to be strong enough for the tension in the spring. Also the carby has locked shut on me a few times :O
Hope it doesn't lock at WOT
I am thinking of changing the throttle servo over to see if this will help, does anyone know what servos HoBao use? They look like Futaba 3003's...
Cheers
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 05-13-2007, 05:45 AM   #640
vc05hdt's Avatar
Originally Posted by hooked_on
Hi
Cheers
If you have an old Novarossi carb, install that and you shouldn't have any issues with tuning and sticking unlike stock Hyper 12 carb. You might need to go to 6 Volt battery pack as you shouldn't have problem with strength of stock servo. Unless damaged?
Old 05-13-2007, 11:33 AM   #641
Default kawahara MTX3 long side belt
hi peepzz.....
just wondering if anyone has any experience with the MTX3 long side belt because I orderd one to loosen up my drivetrain. I know that an original belt is 375T and I woul like to know howmany a longbelt is?!?
Dexter83 is offline   Reply With Quote
Old 05-13-2007, 11:42 AM   #642
Default Stuart
I have been running a GPX4 for the past three months, I am struggling with the clutch dragging, anyone got some wise words?
Other than that the car is great, I am running it with a Rex .12 for the time being as I am new to the sport.
StuartBloys is offline   Reply With Quote
Old 05-13-2007, 02:20 PM   #643
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
I am also having trouble with the chutch. it ejects the flywheel weights I have tried all types of shim combos but no luck any advice or suggestions.
cmain is offline   Reply With Quote
Old 05-13-2007, 04:27 PM   #644
vc05hdt's Avatar
Originally Posted by Dexter83
hi peepzz.....
Yes if you can get MTX3 belts, use them. I am using side and rear at moment and no problems.
Old 05-13-2007, 04:29 PM   #645
vc05hdt's Avatar
I had same problem early on. Set it up as per book with all parts/shims and you shouldn't have problem anymore.
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
