Old 04-21-2007, 04:49 AM   #616
Undies's Avatar
Hi
I am looking to see if i missed anything on this list to build a car with a front diff?
HOBAO (#22001) Front Diff Pully For GPX4
HOBAO (#22130) Alu. Wheel Hub For GPX4
HOBAO (#HB-GPX4S) Hyper GPX4 Pro Car (kit Only)
Intellect (#14005B) 1400mAh 2/3A 6V I-Stick Battery for Receiver
HOBAO (#22003) Diff Case For GPX4
HOBAO (#22004) Diff Bevel Gear For GPX4
HOBAO (#22005) Diff Joint Cup For GPX4
HOBAO (#22038) Side Belt-375 For GPX4
HOBAO (#22039) Front Belt-201 For GPX4
HOBAO (#22040) Rear Belt-192 For GPX4
Also is this the correct battery for the chassis? And would i need anything else?
Look forward to hearing from you shortly.
Undies is offline   Reply With Quote
Old 04-21-2007, 10:55 AM   #617
vc05hdt's Avatar
Originally Posted by Undies
Hi
The battery doesn't look right. I use a hump pack 6V that fits in battery compartment under the fuel tank. Also the belts are factory but if you can get Mugen MTX3 belts, better!!
vc05hdt is offline   Reply With Quote
Old 04-21-2007, 08:18 PM   #618
wancho's Avatar
Default new here!
hi guys. first time in this forum and this hobby. got me my first car, a second hand gpx4 rtr. yeah i know i should've gotten a pro. but hey, with all the posts you guys made, seems like a did pretty good at choosing my first car.
maybe you guys have tips for a newbie whose got bitten by the nitro bug? like a good engine for this thing? or tips on adjusting whatever? i read somewhere that there are cases that this kit has a nasty habit of forgeting to shift to 2nd gear. it'd be great if yous could share some tips on how to get by this.
id love to see more pics of your cars, rtr or pro, to help me get inspired to build this thing up.
thanks and more power to you guys!
wancho is offline   Reply With Quote
Old 04-22-2007, 01:44 AM   #619
Undies's Avatar
Ohhh... from what i read earlier it appeared to be a flat pack the same as the MTX4. Was more interested to see if the parts for the diff were correct as well.
If you got two kits is everything in the box to build a front diff?
Old 04-22-2007, 03:40 AM   #620
vc05hdt's Avatar
I run an RTR car and standard gear diff in front end and back, Pro car one way diff so I cant help. Check through pages as something probably there. If you run front diff, Id use 50000 silicon oil and 30000 back to start and then probably 100000 in front depending on track and your experience. I have changed standard carby for Nova and big difference in tuning (Hyper 12 pullstart), plus Skyline VR12 plus pipe. I run at my track 37 shore foams all round with med bite track. The carb would work with Hyper 12 non pullstart and would be cheap starters motor.
Old 04-22-2007, 03:43 AM   #621
vc05hdt's Avatar
Check my prev reply to Undies, also add MTX3 belts to your ride. Keep factory susp settings to start depending on the track. Front droop about 1-3mm and rear 4mm on mine and handles well. ride height 5.5mm fr, 6-7mm rear.
Old 04-22-2007, 04:26 AM   #622
vc05hdt's Avatar
Default My Ride RTR
I have been in hobby for three years and still enjoying it immensely. Some Pics of my car...... I hope you all like as next body painted to be my personal best design with logos of businesses I work for.
Hobao GPX4 Pro-p1000003edit.jpg   Hobao GPX4 Pro-p1000004edit.jpg   Hobao GPX4 Pro-p1000005edit.jpg   Hobao GPX4 Pro-p1000006edit.jpg
Old 04-24-2007, 11:10 AM   #623
wancho's Avatar
great car. thanks for that belt tip...
you guys know if theres an after market carbon fiber upper deck for the rtr?
Old 04-24-2007, 05:38 PM   #624
vc05hdt's Avatar
I dont think there is one available. I think you don't need it anyway. When setting up your RTR, don't forget to set your end point adjustments (EPA) for throttle and steering as throttle servo will flex the car and you can damage servo's over time forcing them to go further than they really need/ burn out!!
Old 04-26-2007, 07:00 AM   #625
vc05hdt's Avatar
Whats the latest John? Still racing?
Old 04-30-2007, 02:40 AM   #626
Bundy_Bear's Avatar
Hi
Has this car been discontinued? I noticed on the Tower Hobby website the RTR have discontinued or is this just Ofna? Also, the side belt on the RcMart website has been discontinued... Maybe i am looking at too many negatives, but it is looking pair shaped for this car at the moment.
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 05-01-2007, 08:29 AM   #627
vc05hdt's Avatar
Bundy Bear check your mail
Old 05-01-2007, 08:33 AM   #628
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Happy birthday to you, Happy birthday to you, Happy birthday Mark.
and ironic that your G4S shows up on your birthday. see ya sunday
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-01-2007, 12:37 PM   #629
Default side belt sustitution
Hi is anybody can help me. I would like to know if the side belt of the gpx4 is the same of the mtx4 or v-one-rrr, or if has any sustitution. Thanks guys.
alexrgz is offline   Reply With Quote
Old 05-01-2007, 05:17 PM   #630
vc05hdt's Avatar
MTX3 belts substitute for original belts. I am using side and rear, have not tried front yet. They might be getting scarce. Let us know if you get them and where from.
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
