Old 03-19-2007, 01:41 AM   #571
vc05hdt's Avatar
John, I also had toe out front 2 degrees and toe in rear 2 degrees. Other than factory stock FW 05T, power on and off steering good with all my settings. All I need to keep up with club champ is slightly pokier/ higher reving engine.
vc05hdt is offline   Reply With Quote
Old 03-19-2007, 01:56 AM   #572
vc05hdt's Avatar
Originally Posted by JOHN TAN
May I know what is your hyper engine temp range? Mine is always at the high side...
I think my motor was about 240 Degrees F if not a little more but we had a 35 degree celcius day. I tuned to performance and not to temps with this motor as advised from aussie supplier. So tune top end first and then bottom end and make sure plenty of smoke and snappy response. My plug was OS #8 and plug was not fouled. The Novarossi carby was a help too as find the factory carby junk to tune.
Old 03-21-2007, 03:12 AM   #573
Default side belt tention....
hee people! I was wondering if anyone could tell me how to losen my side belt, because it's much to tight! Maybe someone know's of another brand that has a belt that will fit?!?
Dexter83 is offline   Reply With Quote
Old 03-21-2007, 04:26 AM   #574
vc05hdt's Avatar
I was told that a G4 side belt is compatible (see low friction post RC Tech) and Mugen MTX3. I will soon find out as I have bought MTX3 belts I was told that soaking belts in WD40 lubricant for a night or two works as well to lower friction.
Old 03-21-2007, 08:30 AM   #575
mac75's Avatar
Trader Rating: 3 (80%+)
Mtx 3 side belt is more better..
mac75 is offline   Reply With Quote
Old 03-21-2007, 09:50 AM   #576
JOHN TAN's Avatar
Thanks bro...for sharing your setting...
JOHN TAN is offline   Reply With Quote
Old 03-21-2007, 10:00 AM   #577
JOHN TAN's Avatar
Thanks...I have giveup since I don't have good cab to replace...found lot of leakage recently too...so just got the CRF Wasp Rev 2007 .12 engine to match my tuned pipe...
Old 03-21-2007, 10:02 AM   #578
JOHN TAN's Avatar
U can try k-factory which cater for gG4s...it simply loosen up my rolling at least 100% more...
Old 03-21-2007, 04:10 PM   #579
vc05hdt's Avatar
I hope Hobao make some improvement with this motor (Hyper 12). The CRF 2007 from talk at the track v.good. You wont be disappointed.
Old 03-21-2007, 04:18 PM   #580
vc05hdt's Avatar
Good to hear, I bought front,rear,side belts yesterday,THANKS.
John, what part number is this and is it low friction belt?
Old 03-22-2007, 03:55 AM   #581
JOHN TAN's Avatar
Thanks...btw here is my engine yet to break in yet...
Old 03-22-2007, 03:58 AM   #582
JOHN TAN's Avatar
YES it low friction belt from k-factory with no. K1494 ...btw which rear and front belt or there is only one option from mtx-3?
Old 03-22-2007, 12:49 PM   #583
Default side belt
thanks for the replies people! but does anyone know if MTX4 belts will also fit? because the place that I always order from only have kawahara MTX3 belts and they have a normal side belt and a long one, but I do not know witch one to get?!? it's the internetsite:
http://www.the-border.com/product.ph...&cat=14&page=4
please help me, because i have to free up my drivetrain!
Old 03-23-2007, 04:27 AM   #584
vc05hdt's Avatar
I got stock belts. Kawahara i think supply low friction belts for MTX3. If you can get them as Aussie supplier I recall told me run out.(????) Thanks for part number.
Old 03-23-2007, 05:52 AM   #585
OleC's Avatar
I read somewhere about tilting or doing some shimming on the pulley holder for front/middle belts. has anyone tried this for freeing up the drivetrain?
OleC is offline   Reply With Quote
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
